Trying to enable temp chart but I keep getting the below error
I am using a RPi 4
As you can see my cd path is correct?!
Hi there and welcome in our community. The ./edit-config script is under /opt/netdata/etc/netdata dir. Try the same command in this dir.
You will find useful the following topic: Monitoring CPU Temps on RPiX
Thank you!!! That worked ![]()
