Is there away to configure the performance data to show as Fahrenheit instead of Celsius?
Hey @James_Horn,
Welcome to the forums and our little community ![]()
Please, can you specify to which product you refer to? Also, it would be great if you could edit your post and set the category to the appropriate one, probably Support Netdata Agent or Support Netdata Cloud.
cheers !
Hello @James_Horn,
If you are talking about local agent, it is possible you change the unit for Fahrenheit, please, take a look on the next screen
as you can see my Sensor chart is using Celsius, because this is the default, but when I access the settings button on top of Netdata’s dashboard, I have at Locale tab an option to change from Celsius to Fahrenheit. After to change, you need to reload the page, and you have your charts as Fahrenheit:
Best regards!
