mysql_replication
Database | MySQL, MariaDB
This alert monitors the replication status of the MySQL server.
If you receive this, either both or one of the I/O and SQL threads are not running.
This alert is raised into critical if replication has stopped.
In MySQL, replication involves the source database writing down every change made to the data
held within one or more databases in a special file known as the binary log. Once the replica
instance has been initialized, it creates two threaded processes. The first, called the IO
thread, connects to the source MySQL instance and reads the binary log events line by line,
and then copies them over to a local file on the replica’s server called the relay log. The
second thread, called the SQL thread, reads events from the relay log and then applies them
to the replica instance as fast as possible.Recent versions of MySQL support two methods for replicating data. The difference between these
replication methods has to do with how replicas track which database events from the source
they’ve already processed.1
For further information, please have a look at the References and Sources section.
Troubleshooting Section
Check which thread is not running
From the MySQL command line you can run:
For MySQL and MariaDB before v10.2.0:
SHOW SLAVE STATUS\G -
For MariaDB v10.2.0+:
SHOW ALL SLAVES STATUS\G
This will show you three important rows among other info:
Slave_IO_State:
The current status of the replica. See Section 8.14.6, “Replication Replica I/O
Thread States”, and
Section 8.14.7, “Replication Replica SQL Thread
States”, for more
information.Slave_IO_Running:
Whether the I/O thread for reading the source’s binary log is running.
Normally, you want this to be Yes unless you have not yet started replication or have
explicitly stopped it with STOP SLAVE.Slave_SQL_Running:
Whether the SQL thread for executing events in the relay log is running. As
with the I/O thread, this should normally be Yes. 2
For more info you can refer to the MySQL documentation.
