netdata.conf for db size on a Docker container?
My database is growing in size, Id like to keep it small.
How do I best do this on my Docker install? Edit what conf file, do another volume mount within Docker?
I have read
So the default for 3 tiers is 3 GB size? Id like to size down, just keep a DB history for one or maybe two weeks.
Docker container from hub.docker.com
netdata/netdata:latest
running on a Raspberry Pi 5
Have my netdata install resize its DB tiers, so daily backups will shrink in size, too
Thank you!
Hi. Could you please elaborate on the specific issue you’re encountering? It is very straightforward.
Sure / sorry.
On my Docker install, I have a volume mount for /etc/netdata.
Within this directory, there is a file called netdata.conf :
# netdata can generate its own config which is available at 'http://<IP>:19999/netdata.conf'
# You can download it using:
#    curl -o //etc/netdata/netdata.conf http://localhost:19999/netdata.conf
# or
#    wget -O //etc/netdata/netdata.conf http://localhost:19999/netdata.conf
= it’s an empty file. Is this the right file to alter the storage tiers?
Will one setting in this file do the trick for me?
I.e.
[db]
    mode = dbengine
    storage tiers = **2**
    # Tier 0, per second data. Set to 0 for no limit.
    dbengine tier 0 retention size = 1GiB
    dbengine tier 0 retention time = **7d**
    # Tier 1, per minute data. Set to 0 for no limit.
    dbengine tier 1 retention size = 1GiB
    dbengine tier 1 retention time = **14d**
    # Tier 2, per hour data. Set to 0 for no limit.
    #dbengine tier 2 retention size = 1GiB
    #dbengine tier 2 retention time = 2y
Thanks for helping, @ilyam8
Yes. But your syntax is wrong. Why did you add ** for time retention values? If you need only time-based (e.g. 1 week):
[db]
    mode = dbengine
    storage tiers = 1
    dbengine tier 0 retention size = 0
    dbengine tier 0 retention time = 7d
Just read the retention settings for details.
sorry, the ** were added by the forum software because I marked it as bold
I will try it like that now. I was confused before, because my .conf file will have this setting only, nothing else. I was expecting to modify a .conf file with lots more in it.
