Netdata - Nginx Plus API
We are facing an issue with netdata configuration about Nginx Plus and API.
We have installed nginx plus [ nginx/1.19.10 (nginx-plus-r24-p1) ] , we have updated netdata to the version 1.31.0 and we have tried with python 2 and 3 both to solve our issue.
We are trying to install python.d.plugin/nginx_plus (NGINX Plus monitoring with Netdata | Learn Netdata) but perhaps the plugin is based on deprecated methods from python version. The status page that the config is needed is http://localhost/api/6 and not /status, right?
We noticed that after a GET method, the json object which returns is the following error and cannot parse it.
AttributeError(“‘list’ object has no attribute ‘get’”)
but nginx returns
[“nginx”,“processes”,“connections”,“slabs”,“stream”,“http”,“resolvers”,“ssl”]
Can you help us with the configuration and the plugin?
Do you think that there is something else to do from our side?
Hi, @nmarantos :wave:
nginx_plus collector is likely outdated. Related issue plugin python.d/nginx_plus doesn't support new api · Issue #6730 · netdata/netdata · GitHub
Could you try nginxvts collector?
Hi @ilyam8 ,
thank you for your reply.
Yes of course, i will try to configure the nginxvts collector to see if it works!
