Netdata update interval issue
Greetings,
I use netdata for all of my servers. I have a very strange issue like never before.
It’s a physical Ubuntu Server 22.04 with 2 x Intel Platinum CPU’s and 256 GB RAM.
I have a graphic interruptions on every 2 seconds… For example:
03:00:01 - update
03:00:02 - update
03:00:03 - miss
I try default config, I try with "update every = 1s " nothing changed.
Really I don’t have any ideas from where is this issue. I will happy for your help.
Thanks in advance.
Answered on Discord.
You use an ancient third-party version of Netdata instead of our official release.
  • Uninstall the old version.
  • Install latest stable official release.
Greetings,
That is latest official version of Netdata. Just I use /v1 in browser…
Packaging:
    Netdata Version ____________________________________________ : v2.1.0-212-nightly
    Package Distro _____________________________________________ : ubuntu 22.04
    Configure Options __________________________________________ : dummy-configure-command
Default Directories:
Operating System:
    Kernel Version _____________________________________________ : 5.15.0-130-generic
    Operating System ___________________________________________ : Ubuntu
    Operating System ID ________________________________________ : ubuntu
    Operating System ID Like ___________________________________ : debian
    Operating System Version ___________________________________ : 22.04.5 LTS (Jammy Jellyfish)
Hardware:
    CPU Cores __________________________________________________ : 112
    CPU Frequency ______________________________________________ : 3500000000
    RAM Bytes __________________________________________________ : 270032941056
    Disk Capacity ______________________________________________ : 1500312748032
    CPU Architecture ___________________________________________ : x86_64
    Virtualization Technology __________________________________ : none
Container:
Features:
    Memory Allocator ___________________________________________ : system
Database Engines:
    dbengine (compression) _____________________________________ : YES (zstd lz4)
Connectivity Capabilities:
    h2o (web server) ___________________________________________ : NO
Libraries:
    libmnl (library for working with netfilter) ________________ : YES
Plugins:
    Xen ________________________________________________________ : YES
Exporters:
Debug/Developer Features:
