nut_10min_ups_load
Power Supply | UPS
Network UPS Tools (NUT) is a suite of software component designed to monitor power devices, such as uninterruptible power supplies, power distribution units, solar controllers and servers power supply units.
The Netdata Agent monitors the average UPS load over the last 10 minutes.
References and Sources
Troubleshooting section:
Reduce the load on the UPS
To avoid ungraceful shutdowns of your systems, consider to reduce the load on this particular UPS. To achieve this, consider removing attached devices that are not mission critical.
