I’m scraping the prometheus metric endpoint from openziti. The Endpoint is connected tests are showing that the plugin is getting data on the client. But I do not see a graph on the parent.
/etc/netdata/go.d/prometheus.conf
jobs:
- name: openziti_local
url: 'https://127.0.0.1:10004/metrics'
autodetection_retry: 60
tls_skip_verify: yes
#tls_ca: path/to/ca.pem
tls_cert: /certs/prom-client.crt
tls_key: /certs/prom-client.key
sudo ./go.d.plugin -d -m prometheus
CHART 'prometheus_openziti_local.ziti_ingress_rx_msgrate-source_id=vEpkDgvcZw' '' 'ziti_ingress_rx_msgrate' 'msgrate' 'ziti_ingress' 'prometheus.openziti_local.ziti_ingress_rx_msgrate' 'line' '70000' '10' '' 'go.d' 'prometheus'
CLABEL 'source_id' 'vEpkDgvcZw' '1'
CLABEL '_collect_job' 'openziti_local' '1'
CLABEL_COMMIT
DIMENSION 'ziti_ingress_rx_msgrate' 'ziti_ingress_rx_msgrate' 'absolute' '1' '1000' ''
BEGIN 'prometheus_openziti_local.ziti_ingress_rx_msgrate-source_id=vEpkDgvcZw'
SET 'ziti_ingress_rx_msgrate' = 106695
END
Client does not run the web interface.
Client: netdata v1.42.2
Parent: docker netdata/netdata:latest
See a chart with the prometheus metrics
