ethtool can read optic light levels off of newer NICs (using I2C), can this be added to netData to trend? The Tx/Rx light levels of each channel as well as warning/alarm status are what I’m interested in seeing. Other optics might report frequency, BER (bit-error-rate) and possibly SNR. I’ll see if I can dig up an example.
[root@NODE ~]# ethtool -m ens1f1np1
Identifier : 0x03 (SFP)
Extended identifier : 0x04 (GBIC/SFP defined by 2-wire interface ID)
Connector : 0x07 (LC)
Transceiver codes : 0x20 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Transceiver type : 10G Ethernet: 10G Base-LR
Encoding : 0x06 (64B/66B)
BR, Nominal : 10300MBd
Rate identifier : 0x00 (unspecified)
Length (SMF,km) : 10km
Length (SMF) : 10000m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 1310nm
Vendor name : JUNIPER-EQUIV
Vendor OUI : 00:17:6a
Vendor PN : SFPP-10GE-LR-OSI
Vendor rev : B4
Option values : 0x00 0x1a
Option : RX_LOS implemented
Option : TX_FAULT implemented
Option : TX_DISABLE implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : REDACTED
Date code : 080702
Optical diagnostics support : Yes
Laser bias current : 30.812 mA
Laser output power : 0.6880 mW / -1.62 dBm
Receiver signal average optical power : 0.7022 mW / -1.54 dBm
Module temperature : 39.18 degrees C / 102.53 degrees F
Module voltage : 3.2158 V
Alarm/warning flags implemented : Yes
Laser bias current high alarm : Off
Laser bias current low alarm : Off
Laser bias current high warning : Off
Laser bias current low warning : Off
Laser output power high alarm : Off
Laser output power low alarm : Off
Laser output power high warning : Off
Laser output power low warning : Off
Module temperature high alarm : Off
Module temperature low alarm : Off
Module temperature high warning : Off
Module temperature low warning : Off
Module voltage high alarm : Off
Module voltage low alarm : Off
Module voltage high warning : Off
Module voltage low warning : Off
Laser rx power high alarm : Off
Laser rx power low alarm : Off
Laser rx power high warning : Off
Laser rx power low warning : Off
Laser bias current high alarm threshold : 90.000 mA
Laser bias current low alarm threshold : 2.000 mA
Laser bias current high warning threshold : 80.000 mA
Laser bias current low warning threshold : 3.000 mA
Laser output power high alarm threshold : 1.7783 mW / 2.50 dBm
Laser output power low alarm threshold : 0.1995 mW / -7.00 dBm
Laser output power high warning threshold : 1.4125 mW / 1.50 dBm
Laser output power low warning threshold : 0.2512 mW / -6.00 dBm
Module temperature high alarm threshold : 90.00 degrees C / 194.00 degrees F
Module temperature low alarm threshold : -25.00 degrees C / -13.00 degrees F
Module temperature high warning threshold : 85.00 degrees C / 185.00 degrees F
Module temperature low warning threshold : -20.00 degrees C / -4.00 degrees F
Module voltage high alarm threshold : 3.6000 V
Module voltage low alarm threshold : 3.0000 V
Module voltage high warning threshold : 3.5000 V
Module voltage low warning threshold : 3.0500 V
Laser rx power high alarm threshold : 1.0000 mW / 0.00 dBm
Laser rx power low alarm threshold : 0.0158 mW / -18.01 dBm
Laser rx power high warning threshold : 0.7943 mW / -1.00 dBm
Laser rx power low warning threshold : 0.0200 mW / -16.99 dBm
[root@NODE ~]# ethtool -m ens1f1np0
netlink error: no device matches name (offset 24)
netlink error: No such device
[root@NODE ~]# ethtool -m ens3f0np0
Identifier : 0x11 (QSFP28)
Extended identifier : 0x8c
Extended identifier description : 2.5W max. Power consumption
Extended identifier description : CDR present in TX, CDR present in RX
Extended identifier description : High Power Class (> 3.5 W) not enabled
Power set : Off
Power override : On
Connector : 0x0c (MPO Parallel Optic)
Transceiver codes : 0x80 0x00 0x00 0x00 0x40 0x40 0x02 0x00
Transceiver type : 100G Ethernet: 100G Base-SR4 or 25GBase-SR
Transceiver type : FC: short distance (S)
Transceiver type : FC: Shortwave laser w/o OFC (SN)
Transceiver type : FC: Multimode, 50um (OM3)
Encoding : 0x07 ((256B/257B (transcoded FEC-enabled data))
BR, Nominal : 25500Mbps
Length (SMF,km) : 0km
Length (OM3 50um) : 70m
Length (OM2 50um) : 0m
Length (OM1 62.5um) : 0m
Length (Copper or Active cable) : 50m
Transmitter technology : 0x00 (850 nm VCSEL)
Laser wavelength : 850.000nm
Laser wavelength tolerance : 10.000nm
Vendor name : Mellanox
Vendor OUI : 8c:2f:a6
Vendor PN : QSFP28-100G-AOC3
Vendor rev : 10
Date code : 200515
Revision Compliance : SFF-8636 Rev 2.5/2.6/2.7
Module temperature : 54.46 degrees C / 130.03 degrees F
Module voltage : 3.2580 V
Laser tx bias current (Channel 1) : 7.800 mA
Laser tx bias current (Channel 2) : 7.800 mA
Laser tx bias current (Channel 3) : 7.800 mA
Laser tx bias current (Channel 4) : 7.800 mA
Transmit avg optical power (Channel 1) : 0.5186 mW / -2.85 dBm
Transmit avg optical power (Channel 2) : 0.5075 mW / -2.95 dBm
Transmit avg optical power (Channel 3) : 0.5186 mW / -2.85 dBm
Transmit avg optical power (Channel 4) : 0.5433 mW / -2.65 dBm
Rcvr signal avg optical power(Channel 1) : 1.0624 mW / 0.26 dBm
Rcvr signal avg optical power(Channel 2) : 1.0498 mW / 0.21 dBm
Rcvr signal avg optical power(Channel 3) : 1.0647 mW / 0.27 dBm
Rcvr signal avg optical power(Channel 4) : 1.0881 mW / 0.37 dBm
Laser bias current high alarm (Chan 1) : Off
Laser bias current low alarm (Chan 1) : Off
Laser bias current high warning (Chan 1) : Off
Laser bias current low warning (Chan 1) : Off
Laser bias current high alarm (Chan 2) : Off
Laser bias current low alarm (Chan 2) : Off
Laser bias current high warning (Chan 2) : Off
Laser bias current low warning (Chan 2) : Off
Laser bias current high alarm (Chan 3) : Off
Laser bias current low alarm (Chan 3) : Off
Laser bias current high warning (Chan 3) : Off
Laser bias current low warning (Chan 3) : Off
Laser bias current high alarm (Chan 4) : Off
Laser bias current low alarm (Chan 4) : Off
Laser bias current high warning (Chan 4) : Off
Laser bias current low warning (Chan 4) : Off
Laser tx power high alarm (Channel 1) : Off
Laser tx power low alarm (Channel 1) : Off
Laser tx power high warning (Channel 1) : Off
Laser tx power low warning (Channel 1) : Off
Laser tx power high alarm (Channel 2) : Off
Laser tx power low alarm (Channel 2) : Off
Laser tx power high warning (Channel 2) : Off
Laser tx power low warning (Channel 2) : Off
Laser tx power high alarm (Channel 3) : Off
Laser tx power low alarm (Channel 3) : Off
Laser tx power high warning (Channel 3) : Off
Laser tx power low warning (Channel 3) : Off
Laser tx power high alarm (Channel 4) : Off
Laser tx power low alarm (Channel 4) : Off
Laser tx power high warning (Channel 4) : Off
Laser tx power low warning (Channel 4) : Off
Laser rx power high alarm (Channel 1) : Off
Laser rx power low alarm (Channel 1) : Off
Laser rx power high warning (Channel 1) : Off
Laser rx power low warning (Channel 1) : Off
Laser rx power high alarm (Channel 2) : Off
Laser rx power low alarm (Channel 2) : Off
Laser rx power high warning (Channel 2) : Off
Laser rx power low warning (Channel 2) : Off
Laser rx power high alarm (Channel 3) : Off
Laser rx power low alarm (Channel 3) : Off
Laser rx power high warning (Channel 3) : Off
Laser rx power low warning (Channel 3) : Off
Laser rx power high alarm (Channel 4) : Off
Laser rx power low alarm (Channel 4) : Off
Laser rx power high warning (Channel 4) : Off
Laser rx power low warning (Channel 4) : Off
Laser bias current high alarm threshold : 14.000 mA
Laser bias current high warning threshold : 13.000 mA
Laser output power high alarm threshold : 2.1878 mW / 3.40 dBm
Laser output power low alarm threshold : 0.1148 mW / -9.40 dBm
Laser output power high warning threshold : 1.7378 mW / 2.40 dBm
Laser output power low warning threshold : 0.1445 mW / -8.40 dBm
Module temperature high alarm threshold : 80.00 degrees C / 176.00 degrees F
Module temperature low alarm threshold : -10.00 degrees C / 14.00 degrees F
Module temperature high warning threshold : 75.00 degrees C / 167.00 degrees F
Module temperature low warning threshold : 0.00 degrees C / 32.00 degrees F
Module voltage low alarm threshold : 2.9000 V
Module voltage low warning threshold : 3.0000 V
Laser rx power high alarm threshold : 2.1878 mW / 3.40 dBm
Laser rx power low alarm threshold : 0.0794 mW / -11.00 dBm
Laser rx power high warning threshold : 1.7378 mW / 2.40 dBm
Laser rx power low warning threshold : 0.0871 mW / -10.60 dBm
