to see my laptop power consumption till i have find this amazing netdata tool.
Unfortunately my “Sensors” tab is only reporting voltages while my “Power Supply” tab is only showing current charge %.
Is there a way to have access to the actual Watts or Wh?
I’m using docker with the latest container.
So if i make a copy of the conf from e.g. http://localhost:19999/netdata.conf and paste it with that command enabled in “./netdataconfig/” then according to docker command -v ./netdataconfig:/etc/netdata i should be good to go?
Also is there a way to make a Gauge with such value in the “Overview of the key system metrics.”
EDIT:
It seems that if i use ./netdataconfig:/etc/netdata:ro (e.g. local folder in order to copy/paste the new conf) as suggested for docker-compose, the tab “Sensor” disappears. I might open an issue on github soon
That’s the guide i’ve followed but without luck, the “Sensor” tab is disappearing without even touching the config itself. I might look into it tomorrow but i’ve double checked going back to default volumes and “Sensor” tab came back again
~/docker/netstat$ docker logs netdata 2>&1 | grep -E -i "sensor|charts.d"
2021-03-30 06:38:11: netdata INFO : PLUGINSD[charts.d] : thread created with task id 150
2021-03-30 06:38:11: netdata INFO : PLUGINSD[charts.d] : set name of thread 150 to PLUGINSD[charts
2021-03-30 06:38:12: freeipmi.plugin ERROR : MAIN : ipmi_monitoring_sensor_readings_by_record_id(): internal syste m error (errno 2, No such file or directory)
2021-03-30 06:38:13: netdata INFO : PLUGINSD[charts.d] : connected to '/usr/libexec/netdata/plugins.d/charts.d.pl ugin' running on pid 239
2021-03-30 06:38:13: charts.d: INFO: main: started from '/usr/libexec/netdata/plugins.d/charts.d.plugin' with options: 1
2021-03-30 06:38:13: charts.d: INFO: main: Configuration file '/usr/lib/netdata/conf.d/charts.d.conf' loaded.
2021-03-30 06:38:13: charts.d: WARNING: main: Configuration file '/etc/netdata/charts.d.conf' not found.
2021-03-30 06:38:13: charts.d: INFO: example: is disabled. Add a line with example=force in '/etc/netdata/charts.d.conf' to enable it (or remove the line that disables it).
2021-03-30 06:38:13: charts.d: INFO: sensors: is disabled. Add a line with sensors=force in '/etc/netdata/charts.d.conf' to enable it (or remove the line that disables it).
2021-03-30 06:38:13: go.d ERROR: prometheus[pcsensor_temper_exporter_local] Get "http://127.0.0.1:9204/metrics": dial tcp 127.0.0.1:9204: connect: connection refused
2021-03-30 06:38:13: go.d ERROR: prometheus[pcsensor_temper_exporter_local] check failed
2021-03-30 06:38:13: charts.d: WARNING: ap: command 'iw' is not found in /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin.
2021-03-30 06:38:13: charts.d: ERROR: ap: module's 'ap' check() function reports failure.
2021-03-30 06:38:13: charts.d: WARNING: apcupsd: command 'apcaccess' is not found in /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin.
2021-03-30 06:38:13: charts.d: ERROR: apcupsd: module's 'apcupsd' check() function reports failure.
2021-03-30 06:38:13: charts.d: WARNING: libreswan: command 'ipsec' is not found in /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin.
2021-03-30 06:38:13: charts.d: ERROR: libreswan: module's 'libreswan' check() function reports failure.
2021-03-30 06:38:13: charts.d: : nut: command 'upsc -l ' failed with code 127:
2021-03-30 06:38:13: charts.d: ERROR: nut: Cannot find UPSes - please set nut_ups='ups_name' in /nut.conf
2021-03-30 06:38:13: charts.d: ERROR: nut: module's 'nut' check() function reports failure.
2021-03-30 06:38:13: charts.d: WARNING: opensips: command 'opensipsctl' is not found in /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin.
2021-03-30 06:38:13: charts.d: ERROR: opensips: module's 'opensips' check() function reports failure.
2021-03-30 06:38:13: charts.d: FATAL: main: No charts to collect data from.
2021-03-30 06:38:13: netdata INFO : PLUGINSD[charts.d] : called DISABLE. Disabling it.
2021-03-30 06:38:13: netdata INFO : PLUGINSD[charts.d] : PARSER ended
2021-03-30 06:38:13: netdata ERROR : PLUGINSD[charts.d] : '/usr/libexec/netdata/plugins.d/charts.d.plugin' (pid 239) disconnected after 0 successful data collections (ENDs). (errno 22, Invalid argument)
2021-03-30 06:38:13: netdata INFO : PLUGINSD[charts.d] : '/usr/libexec/netdata/plugins.d/charts.d.plugin' (pid 239) does not generate useful output but it reports success (exits with 0). Will not start it again - it is now disabled..
2021-03-30 06:38:13: go.d ERROR: prometheus[pms5003_particulate_matter_sensor_exporter_local] Get "http://127.0.0.1:9662/metrics": dial tcp 127.0.0.1:9662: connect: connection refused
2021-03-30 06:38:13: go.d ERROR: prometheus[pms5003_particulate_matter_sensor_exporter_local] check failed
2021-03-30 06:38:14: python.d INFO: plugin[main] : [sensors] built 1 job(s) configs
2021-03-30 06:38:14: python.d INFO: plugin[main] : [w1sensor] built 1 job(s) configs
2021-03-30 06:38:15: python.d ERROR: sensors[sensors] : b'curr1_input': Can't read
2021-03-30 06:38:15: python.d ERROR: sensors[sensors] : b'in0_input': Can't read
2021-03-30 06:38:16: python.d ERROR: sensors[sensors] : b'curr1_input': Can't read
2021-03-30 06:38:16: python.d ERROR: sensors[sensors] : b'in0_input': Can't read
2021-03-30 06:38:16: python.d INFO: plugin[main] : sensors[sensors] : check success
2021-03-30 06:38:16: python.d ERROR: w1sensor[w1sensor] : [Errno 2] No such file or directory: '/sys/bus/w1/devices/'
2021-03-30 06:38:16: python.d INFO: plugin[main] : w1sensor[w1sensor] : check failed
But i have noticed that after few minutes the “Sensors” tab appears again (i retyped the command but the result has been the same)
i have added in the config the command above and by browsing it via URL i see the following
# section 'plugin:proc:/sys/class/power_supply' is not used.
[plugin:proc:/sys/class/power_supply]
battery energy = yes
Moreover i’ve noticed that if the AC is connected (e.g. battery charging) i can see the current (not the energy) and when there is only BAT0 i can see only the voltage (i can always see the temperature otherwise)
am i wrong in thinking that the default behavior is “yes” when it is written a such?
Anyway i’ve changed it and now the config is shown as such
# battery capacity = yes
# battery charge = no
# power supply voltage = no
# keep files open = auto
# directory to monitor = /host/sys/class/power_supply
but yet i can’t see it.
Powersupply → BAT0 is only showing capacity
Sensors is only showing voltage
