Slack Notification is recurring
Hey there,
we recently started to use Netdata on our servers and have some trouble with the Slack-Notification. In general, it works fine an as expected, but sometimes we keep getting the same notification multiple times. In the screenshot you can see, that we have the same recovering-message (dated to the 27th of February), once from yesterday, once from today (without a warning in between). It’s not the first time, we’ve noticed that. I think the last time we deactivated Slack for some time and afterwards, it worked fine again.
Any ideas about this?
Hi @benedikt.allendorf :wave:
Let’s check error.log, perhaps Netdata failed to send warning notification for some reason.
grep "slack notification" error.log
Hey,
that shows some INFOs like “[…] is CLEAR/WARNING without specifying a channel” (seems like for every Slack notification we get). Could that already be part of the problem? We don’t get duplicates for each notification, only for a few.
Edit: Additionally, the notifications we get (at least mostly) are not from the servers running netdata themselves but instead we have one node which receives streaming and sends the (Slack) Notifications.
Is it possible to copy and paste in a code block the error log as indicated by @ilyam8 ? That log should originate from the node which receives the streaming data and runs the health checks (parent node).
Sure, the full log looks like this:
Summary
2021-03-03 06:46:58: alarm-notify.sh: INFO: sent slack notification for: ServerA mem.available.ram_available is CLEAR without specifying a channel
2021-03-04 07:23:38: alarm-notify.sh: INFO: sent slack notification for: ServerA mem.available.ram_available is CLEAR without specifying a channel
2021-03-04 10:06:43: alarm-notify.sh: INFO: sent slack notification for: ServerB mem.available.ram_available is WARNING without specifying a channel
2021-03-04 10:07:53: alarm-notify.sh: INFO: sent slack notification for: ServerB system.ram.ram_in_use is WARNING without specifying a channel
2021-03-04 10:39:14: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is WARNING without specifying a channel
2021-03-04 10:39:24: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is WARNING without specifying a channel
2021-03-04 10:45:15: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is CLEAR without specifying a channel
2021-03-04 10:45:15: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is CLEAR without specifying a channel
2021-03-04 10:55:55: alarm-notify.sh: INFO: sent slack notification for: ServerB mem.available.ram_available is CRITICAL without specifying a channel
2021-03-04 12:46:04: alarm-notify.sh: INFO: sent slack notification for: ServerB system.ram.ram_in_use is CLEAR without specifying a channel
2021-03-04 12:49:34: alarm-notify.sh: INFO: sent slack notification for: ServerB mem.available.ram_available is CLEAR without specifying a channel
2021-03-04 13:29:43: alarm-notify.sh: INFO: sent slack notification for: ServerD disk_backlog.sda.10min_disk_backlog is WARNING without specifying a channel
2021-03-04 13:50:44: alarm-notify.sh: INFO: sent slack notification for: ServerD disk_backlog.sda.10min_disk_backlog is CLEAR without specifying a channel
2021-03-04 14:54:14: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is WARNING without specifying a channel
2021-03-04 14:54:26: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is WARNING without specifying a channel
2021-03-04 15:00:24: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is CLEAR without specifying a channel
2021-03-04 15:00:24: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is CLEAR without specifying a channel
2021-03-04 18:02:55: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is WARNING without specifying a channel
2021-03-04 18:03:04: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is WARNING without specifying a channel
2021-03-04 18:09:24: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is CLEAR without specifying a channel
2021-03-04 18:09:24: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is CLEAR without specifying a channel
2021-03-04 21:04:43: alarm-notify.sh: INFO: sent slack notification for: ServerD disk_backlog.sda.10min_disk_backlog is WARNING without specifying a channel
2021-03-04 21:29:43: alarm-notify.sh: INFO: sent slack notification for: ServerD disk_backlog.sda.10min_disk_backlog is CLEAR without specifying a channel
2021-03-04 22:27:24: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is WARNING without specifying a channel
2021-03-04 22:28:09: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is WARNING without specifying a channel
2021-03-04 22:33:44: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is CLEAR without specifying a channel
2021-03-04 22:33:44: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is CLEAR without specifying a channel
2021-03-04 23:07:14: alarm-notify.sh: INFO: sent slack notification for: ServerB disk_backlog.sda.10min_disk_backlog is WARNING without specifying a channel
2021-03-04 23:33:15: alarm-notify.sh: INFO: sent slack notification for: ServerB disk_backlog.sda.10min_disk_backlog is CLEAR without specifying a channel
2021-03-05 00:13:15: alarm-notify.sh: INFO: sent slack notification for: ServerE disk_backlog.sda.10min_disk_backlog is WARNING without specifying a channel
2021-03-05 00:34:14: alarm-notify.sh: INFO: sent slack notification for: ServerE disk_backlog.sda.10min_disk_backlog is CLEAR without specifying a channel
2021-03-05 06:49:55: alarm-notify.sh: INFO: sent slack notification for: ServerF web_log_apache_vhosts.excluded_requests.web_log_1m_unmatched is WARNING without specifying a channel
2021-03-05 07:00:15: alarm-notify.sh: INFO: sent slack notification for: ServerA mem.available.ram_available is CLEAR without specifying a channel
2021-03-05 07:00:15: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is CLEAR without specifying a channel
2021-03-05 07:00:15: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is CLEAR without specifying a channel
2021-03-05 07:10:14: alarm-notify.sh: INFO: sent slack notification for: ServerF web_log_apache_vhosts.excluded_requests.web_log_1m_unmatched is CLEAR without specifying a channel
2021-03-05 09:03:14: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is WARNING without specifying a channel
2021-03-05 09:03:25: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is WARNING without specifying a channel
2021-03-05 09:10:14: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_accept_queue.1m_tcp_accept_queue_drops is CLEAR without specifying a channel
2021-03-05 09:10:14: alarm-notify.sh: INFO: sent slack notification for: ServerC ip.tcp_syn_queue.1m_tcp_syn_queue_cookies is CLEAR without specifying a channel
I analyzed the logs, according them:
  • there is no failed to send events
  • indeed, sometimes there is several sequential CLEAR w/o WARN/CRIT in between
See [!!!], it means wrong transition
ServerA
  └mem.available.ram_available
    └CLEAR->[!!!]CLEAR->[!!!]CLEAR
ServerB
    └WARNING->CRITICAL->CLEAR
  └system.ram.ram_in_use
    └WARNING->CLEAR
  └disk_backlog.sda.10min_disk_backlog
    └WARNING->CLEAR
ServerC
  └ip.tcp_accept_queue.1m_tcp_accept_queue_drops
    └WARNING->CLEAR->WARNING->CLEAR->WARNING->CLEAR->WARNING->CLEAR->[!!!]CLEAR->WARNING->CLEAR
  └ip.tcp_syn_queue.1m_tcp_syn_queue_cookies
ServerD
ServerE
    └WARNING->CLEAR
ServerF
  └web_log_apache_vhosts.excluded_requests.web_log_1m_unmatched
    └WARNING->CLEAR
Will be much easier to debug when [health] Dispatch some alarms into health.log instead of debug by Saruspete · Pull Request #7576 · netdata/netdata · GitHub is merged.
Is there anything else I could look up or do? Or should I just wait for that Pull Requests?
Does it happen only with CLEAR notifications?
Mostly, but not exclusively I think.
When scrolling through the Slack channel I found at least one Warning that was dated to two days before (but apparently not sent at all on the original day. So more a delay than a duplicate). Those were swap-WARNINGs which happened multiple times per day (and were cleared multiple times). And one time the CLEAR occurred on the next day, maybe that broke something.
