Coming from ESXi I am doing my first steps with XCP-ng. I wanted to integrate Netdata as well as XCP-ng is featured as supported environment.
According to instructions I ssh to my XCP-ng installation and executed:
yum install xen-dom0-libs-devel
yum install yajl-devel
yum install xen-devel
without issues. I don’t now how to add centos-release-xen repository - hoping this is not needed. When then trying to execute
wget -O /tmp/netdata-kickstart.sh h**ps://get.netdata.cloud/kickstart.sh && sh /tmp/netdata-kickstart.sh
I get this result:
[**10:04** **localhost** ~]# wget -O /tmp/netdata-kickstart.sh h**ps://get.netdata.cloud/kickstart.sh && sh /tmp/netdata-kickstart.sh
--2024-02-22 10:04:34-- h**ps://get.netdata.cloud/kickstart.sh
Auflösen des Hostnamen »get.netdata.cloud (get.netdata.cloud)«... 172.67.72.170, 104.26.8.141, 104.26.9.141, ...
Verbindungsaufbau zu get.netdata.cloud (get.netdata.cloud)|172.67.72.170|:443... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 88187 (86K) [application/octet-stream]
In »»/tmp/netdata-kickstart.sh«« speichern.
100%[========================================================================================================================================================================================>] 88.187 --.-K/s in 0,007s
2024-02-22 10:04:34 (11,9 MB/s) - »»/tmp/netdata-kickstart.sh«« gespeichert [88187/88187]
--- **Using /tmp/netdata-kickstart-Ca6oWZBJ9E as a temporary directory.** ---
--- **Checking for existing installations of Netdata...** ---
--- **No existing installations of netdata found, assuming this is a fresh install.** ---
**WARNING** Unable to determine Linux distribution for native packages.
**WARNING** Could not install native binary packages, falling back to alternative installation method.
[/tmp/netdata-kickstart-Ca6oWZBJ9E]# **sh -c /usr/bin/curl h**ps://github.com/netdata/netdata-nightlies/releases/latest -s -L -I -o /dev/null -w '%{url_effective}' | grep -Eo '[^/]+$'**
**OK**
--- **Attempting to install using static build...** ---
[/tmp/netdata-kickstart-Ca6oWZBJ9E]# **/usr/bin/curl --fail -q -sSL --connect-timeout 10 --retry 3 --output /tmp/netdata-kickstart-Ca6oWZBJ9E/netdata-x86_64-latest.gz.run h**ps://github.com/netdata/netdata-nightlies/releases/download/v1.44.0-400-nightly/netdata-x86_64-latest.gz.run**
curl: (35) Cannot communicate securely with peer: no common encryption algorithm(s).
**FAILED**
- Unable to determine Linux distribution for native packages.
- Could not install native binary packages, falling back to alternative installation method.
- Command "/usr/bin/curl --fail -q -sSL --connect-timeout 10 --retry 3 --output /tmp/netdata-kickstart-Ca6oWZBJ9E/netdata-x86_64-latest.gz.run h**ps://github.com/netdata/netdata-nightlies/releases/download/v1.44.0-400-nightly/netdata-x86_64-latest.gz.run" failed with exit code 35.
**ABORTED** Unable to download static build archive for x86_64. This is usually a result of a networking issue.
For community support, you can connect with us on:
[/root]# **rm -rf /tmp/netdata-kickstart-Ca6oWZBJ9E**
**OK**
What am I doing wrong?
Thank you in advance.
PS: It’s hard to protocol the issue with only 5 links allowed.
