Hello i have issue where dashboard app show my servers as unseen
Packaging:
Netdata Version ____________________________________________ : v1.42.4
Installation Type __________________________________________ : custom
Package Architecture _______________________________________ : unknown
Package Distro _____________________________________________ : unknown
Configure Options __________________________________________ : '--build=x86_64-redhat-linux-gnu' '--host=x86_64-redhat-linux-gnu' '--program-prefix=' '--disable-dependency-tracking' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib64' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/var/lib' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--enable-plugin-freeipmi' '--with-bundled-protobuf' '--with-zlib' '--with-math' '--with-user=netdata' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic' 'LDFLAGS=-Wl,-z,relro -specs=/usr/lib/rpm/redhat/redhat-hardened-ld' 'CXXFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic' 'PKG_CONFIG_PATH=:/usr/lib64/pkgconfig:/usr/share/pkgconfig'
Default Directories:
Stock Configurations _______________________________________ : /usr/lib64/netdata/conf.d
Operating System:
Kernel Version _____________________________________________ : 3.10.0-962.3.2.lve1.5.81.el7.x86_64
Operating System ___________________________________________ : CloudLinux
Operating System ID ________________________________________ : cloudlinux
Operating System ID Like ___________________________________ : rhel fedora centos
Operating System Version ___________________________________ : 7.9 (Boris Yegorov)
Hardware:
CPU Cores __________________________________________________ : 12
CPU Frequency ______________________________________________ : 4700000000
CPU Architecture ___________________________________________ : 67235348480
RAM Bytes __________________________________________________ : 1920394248192
Disk Capacity ______________________________________________ : x86_64
Virtualization Technology __________________________________ : none
Container:
Features:
Streaming and Replication Compression ______________________ : NO (none)
Database Engines:
dbengine ___________________________________________________ : YES
map ________________________________________________________ : YES
save _______________________________________________________ : YES
Connectivity Capabilities:
Libraries:
LZ4 (extremely fast lossless compression algorithm) ________ : NO
Judy (high-performance dynamic arrays and hashtables) ______ : YES (bundled)
dlib (robust machine learning toolkit) _____________________ : YES (bundled)
protobuf (platform-neutral data serialization protocol) ____ : YES (bundled)
libcap (Linux capabilities system operations) ______________ : YES
libm (mathematical functions) ______________________________ : YES
jemalloc ___________________________________________________ : NO
TCMalloc ___________________________________________________ : NO
Plugins:
cups (monitor printers and print jobs) _____________________ : NO
ebpf (monitor system calls) ________________________________ : NO
nfacct (gather netfilter accounting) _______________________ : NO
Xen ________________________________________________________ : NO
Exporters:
MongoDB ____________________________________________________ : NO
Debug/Developer Features:
ystemctl status netdata
Loaded: loaded (/usr/lib/systemd/system/netdata.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2023-10-08 01:47:59 CEST; 5min ago
Main PID: 648990 (netdata)
├─648990 /opt/netdata/bin/srv/netdata -D
├─648992 /opt/netdata/bin/srv/netdata --special-spawn-server
├─649156 bash /opt/netdata/usr/libexec/netdata/plugins.d/tc-qos-helper.sh 1
├─649176 /opt/netdata/usr/libexec/netdata/plugins.d/go.d.plugin 1
├─649179 /opt/netdata/usr/libexec/netdata/plugins.d/apps.plugin 1
├─649181 /usr/bin/python3 /opt/netdata/usr/libexec/netdata/plugins.d/python.d.plugin 1
├─649182 /opt/netdata/usr/libexec/netdata/plugins.d/nfacct.plugin 1
└─649187 /opt/netdata/usr/libexec/netdata/plugins.d/debugfs.plugin 1
cloudlinux 7.9 dedicated server
