whoisquery_days_until_expiration
Other | WHOIS
The Netdata Agent checks the time until the domain name registration expires. This alert indicates that the domain name registration expires soon. If you do not renew the domain it will be deactivated soon. Consider scheduling the renewal.
This alert is raised into warning when your domain is about to expire in less than 90 days and in critical when it will expire in less than 30 days.
Troubleshooting section
If you still want this domain you should renew it. If you need help renewing your domain name, you should immediately contact the registrar (or reseller) that provided your domain name registration services for possible renewal options available to you.
To determine your current registrar of record, you may conduct a WHOIS search by visiting whois.icann.org. Registrar information can be found on the ICANN-Accredited Registrar list.
