Environment
Server: Ubuntu 20.04.2 LTS (GNU/Linux 5.4.0-73-generic x86_64)
Netdata: v1.30.1
go.plugin whois monitor cant get correct expiration time, and the value is always -9223372036.
conf
# ------------------------------------------------MODULE-CONFIGURATION--------------------------------------------------
# [ GLOBAL ]
update_every: 60
# autodetection_retry: 0
# priority: 70000
# jobs:
# - name: example
# source: example.org
jobs:
- name: annangela.cn
source: annangela.cn
days_until_expiration_warning: 14
days_until_expiration_critical: 7
Troubleshooting output
[ DEBUG ] run[manager] run.go:41 tick 60
CHART 'netdata.execution_time_of_whoisquery_annangela.cn' '' 'Execution Time for whoisquery_annangela.cn' 'ms' 'go.d' 'netdata.go_plugin_execution_time' '' '145000' '60' '' 'go.d' 'whoisquery'
DIMENSION 'time' '' '' '1' '1' ''
CHART 'whoisquery_annangela.cn.time_until_expiration' '' 'Time Until Domain Expiration' 'seconds' 'expiration time' 'whoisquery.time_until_expiration' '' '70000' '60' 'store_first' 'go.d' 'whoisquery'
DIMENSION 'expiry' '' '' '1' '1' ''
VARIABLE CHART 'days_until_expiration_warning' = 0
VARIABLE CHART 'days_until_expiration_critical' = 0
BEGIN 'whoisquery_annangela.cn.time_until_expiration'
SET 'expiry' = -9223372036
VARIABLE CHART 'days_until_expiration_warning' = 14
VARIABLE CHART 'days_until_expiration_critical' = 7
END
BEGIN 'netdata.execution_time_of_whoisquery_annangela.cn'
SET 'time' = 593
END
Show correct expiration time.
Hi @AnnAngela
I confirm the bug. The reason is whoisquery collector fails to parse the domain expiration date. We will fix it!
ilyam8
May 17, 2021, 10:33am
3
I created an issue and made a PR with the fix .
@AnnAngela thanks for reporting the problem!
Thx for fixing it, and I would like to ask when the fix wil be released? @ilyam8
ilyam8
May 18, 2021, 12:08pm
5
I think it is going to be next week. We are about to release new version of Netdata, then code freeze for several days…
You can build the plugin from the source and start using it today. Do you need a guide how to do it?
No, I will just wait the next release. Thx you again for quick fixing.
If I wasn’t clear, let me reword it - the fix doesn’t make it into the upcoming stable release (v1.31.0). Will be available in the nightly branch after v1.31.0.
Hmmmm, I remember that the doc encourages user to use nightly build. Is it any different between nightly build and nightly branch?
build/branch is the same (in fact I wanted to say channel, not branch )
So if I didn’t misunderstand your meaning, you said that the fix missed up next nightly build, it’s still in dev/nightly channel and need to wait the next nightly build after the next one? If so, I would like to try to build the plugin from the source.
ilyam8
May 19, 2021, 3:26pm
11
Here you go, you need Golang v1.14+ I believe.
git clone https://github.com/netdata/go.d.plugin
cd go.d.plugin
make build
# that is all
# now you have bin/godplugin in the current directory
systemctl stop netdata.service
# could be not `/opt/netdata/` for you, depends on your install prefix
cp bin/godplugin /opt/netdata/usr/libexec/netdata/plugins.d/go.d.plugin
systemctl start netdata.service
Confirmed that the bug has been addressed after you pr, thank you!
ilyam8
May 24, 2021, 1:35pm
13
@AnnAngela btw, it was a bug, next time consider opening a bug report on GitHub.
Note for @me : I should have opened it after I realized that it was a bug
omg, i did it i blame Monday , nvm
