Hey Again,
I’ve created an Netdate Instance to Monitor my 2 ESXi Hosts. if i look at the Alert Logs the Friendly Value is on Over 80% and the Status is still clear, how can that be?
Thx for your Time & Support ![]()
Hey Again,
Check what the warning when and critical when expressions actually say. When there is no active alarm (status < WARNING), the limit to trigger the alarm is 90. 70 is used as the value below which the alarm will be cleared, IF at some point it went over 90 (i.e. have status >= WARNING) and the value is then coming down.
