Anyone willing to help?
Any one willing to help me with a system.uptime alarme? I would like to build an uptime alarme to check every min or so for the sistem to be online
Many thanks
Hi @ACASA_TV ! Welcome to the Netdata community.
What exactly do you want to check? That the system the Netdata agent is running is connected to the internet?
Hi Manolis I am trying to achieve an alarm to check every minute or so if the system is online, I don’t mind if is checking for netdata,but to make sure the server is online
Howdy!
I think the fping collector is maybe what you need here.
Once enabled and configured it will have these alarms
https://raw.githubusercontent.com/netdata/netdata/master/health/health.d/fping.conf
And so I think the fping_host_reachable alarm template would be the out it the box alert which you could edit a bit if you wanted bit probably fine as is to start with.
Many thanks @andrewm4894 this is what i was looking for
