On 2 out of 11 nodes this sidebar applications was lost…
Netdata Agent:
v1.38.0-228-nightly
Can you please verify that in netdata.conf you see
[plugins]
# apps = yes
If you do see that, then please look for errors in the log with apps.plugin.
reinstall helped thank you.
happened again. turns out just running update command helped.
