Can't connect to cloud when trying to claim node
Node claiming fails with a problem connecting to app.netdata.cloud.
Failed to connect to https://app.netdata.cloud, return code 60
Connection attempt 1 failed. Retry in 1s.
Connection attempt 2 failed. Retry in 2s.
Connection attempt 3 failed. Retry in 3s.
The node is on Linode and from there I cannot ping app.netdata.cloud and a traceroute hangs up on an akamai node. Perhaps this is normal ICMP blocking for security.
The netdata clound is an AWS ingress point:
❯ dig app.netdata.cloud
main-ingress-545609a41fcaf5d6.elb.us-east-1.amazonaws.com.
54.198.178.11
44.207.131.212
44.196.50.41
And if I tshark the connection I do see an expired certificate alert. Could that be the problem?
338 9.957636811 172.105.152.168 → 44.196.50.41 TLSv1.2 73 Alert (Level: Fatal, Description: Certificate Expired)
Ah wait, maybe it’s a certificate problem on the NODE side! This is a node that for for idiotic reasons has not been updated in a while.
Hey!
You are not alone with this problem. Problem is that ~middle 2021, Let’s Encrypt changed their certificate chain. Because of that many systems that are not updated often enough faced the problem of not trusting our current certificate. Your machine does not trust us because path of certification is not trusted for it.
But just to be sure I checked our app.netdata.cloud and it looks healthy:
openssl s_client -connect app.netdata.cloud:443 | openssl x509 -noout -dates
depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = app.netdata.cloud
verify return:1
notBefore=Oct 19 06:50:32 2022 GMT
notAfter=Jan 17 06:50:31 2023 GMT
Have a nice day
Mat
Thanks for confirming that is the issue @Mateusz_Bularz. We actually have a thread on the forum about that, so @nedludd please check this thread Certificate verification error connecting to the cloud
Hope you get it sorted out.
Regards,
Hugo
