Error (return code) 60 when trying to claim code when trying to connect node with cloud service
Hi Team,
When I am trying to claim a node it fails with return code 60.
Failed to connect to https://app.netdata.cloud, return code 60
Connection attempt 3 failed. Retry in 3s.
grep: /var/lib/netdata/cloud.d/tmpout.txt: No such file or directory
Failed to claim node with the following error message:"Unknown HTTP error message"
Also I noticed, 2 files are missing in the cloud.d files:
claimed_id
cloud.conf
Tried running the netdata-claim.sh
It throws a token error.
Token: ****************
Base URL: https://app.netdata.cloud
Rooms:
Hostname: 60220200025-LIVE
Proxy:
Netdata user: netdata
Connection attempt 1 failed. Retry in 1s.
Connection attempt 2 failed. Retry in 2s.
Environment
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
Can you check if it’s due to Certificate verification error connecting to the cloud ?
