I am new to Netdata and trying to install the agent on some servers to test. When I paste the install code from my cloud account it begins fine and installs but at the end I am getting the following issue
Extracting public key from private key.
writing RSA key
Failed to connect to https://app.netdata.cloud, return code 60
Connection attempt 1 failed. Retry in 1s.
Connection attempt 2 failed. Retry in 2s.
Connection attempt 3 failed. Retry in 3s.
grep: /opt/netdata/var/lib/netdata/cloud.d/tmpout.txt: No such file or directory
Failed to claim node with the following error message:“Unknown HTTP error message”
WARNING Unable to claim node, you must do so manually.
I have tried this on multiple servers and get the same results. Any help would be appreciated.
Hello @John_Aucoin sorry for the late response, welcome in our community. Let me help you.
Have you installed the Agent in the the particular node? What steps have you made so far?
I have copied the code from my account and tried to install it on multiple servers. It installs the net data client fine but never claims
Thanks
John
Ok, let’s be more specific and focus on one node. Could you please answer to the followings:
- Node’s OS, version of kernel
- Share your Netdata version and build (run
netdata -W buildinfo )
- Could you access the Agent’s dashboard in this host? (It listens on port :19999)
Did you solve this issue? I think it is a kernel or SO related issue, not sure. In a Debian 8 relase the issue is present, but not in a Debian 10. I solved the problem using:
export PATH=“/opt/netdata/bin:${PATH}”
I used this solution from [Feat]: netdata-claim.sh is too cryptic, documentation missing · Issue #12186 · netdata/netdata · GitHub
Hello @g4br13l24 and welcome into our community
You mean that you faced the same error
. . .I am getting the following issue
writing RSA key
And it resolved just by adding/including the Netdata’s bin (you have static builds that’s why Agent is under /opt) folder into your path?
I am just curious not arguing, I am just aware that error code 60 is related to ca-certificates issues.
I think that just an update of the ca-certificates fixes the issue.
I will try to reproduce it in Debian 8 and let you know
Hello @Tasos_Katsoulas
Thank you! Yes, I faced same issue.
I’m pretty sure the above message it was the same, with 60 error code.
