Suggested template:
Netdata agent is unable to connect with netdata cloud
I can’t find the link now.
Edge latest
It is supposed to connect.
I’m having the same issue on brand new ubuntu jammy installation and brand new netdata installation.
Here is the installed ca-certicates package
root@server:/opt# apt-cache policy ca-certificates
ca-certificates:
Installed: 20211016
Candidate: 20211016
Version table:
*** 20211016 500
500 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages
100 /var/lib/dpkg/status
aclk status
root@server:/opt# netdatacli aclk-state
ACLK Available: Yes
ACLK Version: 2
Protocols Supported: Protobuf
Protocol Used: Protobuf
MQTT Version: 5
Claimed: Yes
Claimed Id: xxxxxxxxxx-xxx-xxxx-xxxx-xxxxxxx
Online: No
Reconnect count: 0
Banned By Cloud: No
Next Connection Attempt At: 2022-12-03 03:25:03
Last Backoff: 20.029
2022-12-03 03:24:24: netdata INFO : ACLK_Main : Attempting connection now
2022-12-03 03:24:24: netdata ERROR : ACLK_Main : Cert Chain verify error:num=20:unable to get local issuer certificate:depth=2:/C=US/O=Internet Security Research Group/CN=ISRG Root X1 (errno 2, No such file or directory)
2022-12-03 03:24:24: netdata ERROR : ACLK_Main : SSL_write Err: SSL_ERROR_SSL
2022-12-03 03:24:24: netdata ERROR : ACLK_Main : Couldn’t write HTTP request header into SSL connection
2022-12-03 03:24:24: netdata ERROR : ACLK_Main : Couldn’t process request
2022-12-03 03:24:24: netdata ERROR : ACLK_Main : Error trying to contact env endpoint
2022-12-03 03:24:24: netdata ERROR : ACLK_Main : Failed to Get ACLK environment
2022-12-03 03:24:24: netdata INFO : ACLK_Main : Wait before attempting to reconnect in 2.071 seconds2022-12-03 03:24:26: netdata INFO : ACLK_Main : Attempting connection now
2022-12-03 03:24:26: netdata ERROR : ACLK_Main : Cert Chain verify error:num=20:unable to get local issuer certificate:depth=2:/C=US/O=Internet Security Research Group/CN=ISRG Root X1 (errno 2, No such file or directory)
2022-12-03 03:24:26: netdata ERROR : ACLK_Main : SSL_write Err: SSL_ERROR_SSL
2022-12-03 03:24:26: netdata ERROR : ACLK_Main : Couldn’t write HTTP request header into SSL connection
2022-12-03 03:24:26: netdata ERROR : ACLK_Main : Couldn’t process request
2022-12-03 03:24:26: netdata ERROR : ACLK_Main : Error trying to contact env endpoint
2022-12-03 03:24:26: netdata ERROR : ACLK_Main : Failed to Get ACLK environment
2022-12-03 03:24:26: netdata INFO : ACLK_Main : Wait before attempting to reconnect in 5.409 seconds2022-12-03 03:24:32: netdata INFO : ACLK_Main : Attempting connection now
2022-12-03 03:24:32: netdata ERROR : ACLK_Main : Cert Chain verify error:num=20:unable to get local issuer certificate:depth=2:/C=US/O=Internet Security Research Group/CN=ISRG Root X1 (errno 2, No such file or directory)
2022-12-03 03:24:32: netdata ERROR : ACLK_Main : SSL_write Err: SSL_ERROR_SSL
2022-12-03 03:24:32: netdata ERROR : ACLK_Main : Couldn’t write HTTP request header into SSL connection
2022-12-03 03:24:32: netdata ERROR : ACLK_Main : Couldn’t process request
2022-12-03 03:24:32: netdata ERROR : ACLK_Main : Error trying to contact env endpoint
2022-12-03 03:24:32: netdata ERROR : ACLK_Main : Failed to Get ACLK environment
2022-12-03 03:24:32: netdata INFO : ACLK_Main : Wait before attempting to reconnect in 11.109 seconds2022-12-03 03:24:43: netdata INFO : ACLK_Main : Attempting connection now
2022-12-03 03:24:43: netdata ERROR : ACLK_Main : Cert Chain verify error:num=20:unable to get local issuer certificate:depth=2:/C=US/O=Internet Security Research Group/CN=ISRG Root X1 (errno 2, No such file or directory)
2022-12-03 03:24:43: netdata ERROR : ACLK_Main : SSL_write Err: SSL_ERROR_SSL
2022-12-03 03:24:43: netdata ERROR : ACLK_Main : Couldn’t write HTTP request header into SSL connection
2022-12-03 03:24:43: netdata ERROR : ACLK_Main : Couldn’t process request
2022-12-03 03:24:43: netdata ERROR : ACLK_Main : Error trying to contact env endpoint
2022-12-03 03:24:43: netdata ERROR : ACLK_Main : Failed to Get ACLK environment
2022-12-03 03:24:43: netdata INFO : ACLK_Main : Wait before attempting to reconnect in 20.029 seconds2022-12-03 03:24:45: netdata ERROR : HEALTH[GSB10G-20] : Failed to prepare statement when trying to filter alert events.
2022-12-03 03:24:45: netdata ERROR : HEALTH[GSB10G-20] : Failed to prepare statement to store alert event
2022-12-03 03:24:58: netdata INFO : MAIN : Command Clients = 12022-12-03 03:24:58: netdata INFO : MAIN : EOF found in command pipe.
2022-12-03 03:24:58: netdata INFO : MAIN : COMMAND: Reopening aclk/cloud state.
2022-12-03 03:24:58: netdata INFO : MAIN : COMMAND: Sending reply: “X0”
2022-12-03 03:24:58: netdata INFO : MAIN : Command Clients = 02022-12-03 03:25:03: netdata INFO : ACLK_Main : Attempting connection now
2022-12-03 03:25:03: netdata ERROR : ACLK_Main : Cert Chain verify error:num=20:unable to get local issuer certificate:depth=2:/C=US/O=Internet Security Research Group/CN=ISRG Root X1 (errno 2, No such file or directory)
2022-12-03 03:25:03: netdata ERROR : ACLK_Main : SSL_write Err: SSL_ERROR_SSL
2022-12-03 03:25:03: netdata ERROR : ACLK_Main : Couldn’t write HTTP request header into SSL connection
2022-12-03 03:25:03: netdata ERROR : ACLK_Main : Couldn’t process request
2022-12-03 03:25:03: netdata ERROR : ACLK_Main : Error trying to contact env endpoint
2022-12-03 03:25:03: netdata ERROR : ACLK_Main : Failed to Get ACLK environment
2022-12-03 03:25:03: netdata INFO : ACLK_Main : Wait before attempting to reconnect in 39.480 seconds
Please any help here? I tried on some other machines as well and all same issue.
