CentOS 7.5 Minimal 64bit
Install https://i.imgur.com/rtECpHF.png
Uninstall https://i.imgur.com/57DzM8L.png
VPS specs https://i.imgur.com/wvMU4qd.png
Cloud status: https://i.imgur.com/f17NrTs.png
Hi @admiral504 ! Welcome to Netdata.
First question, are you running the scripts as root?
yes i am. you can see root@… in my screenshot sir
Can you please paste the output of /usr/sbin/netdata -W buildinfo ?
sorry for late reply
[root@cheap-rocket-8g ~]# /usr/sbin/netdata -W buildinfo
Version: netdata v1.36.1
Configure options: ‘–build=x86_64-redhat-linux-gnu’ ‘–host=x86_64-redhat-linu x-gnu’ ‘–program-prefix=’ ‘–disable-dependency-tracking’ ‘–prefix=/usr’ ‘–ex ec-prefix=/usr’ ‘–bindir=/usr/bin’ ‘–sbindir=/usr/sbin’ ‘–sysconfdir=/etc’ ‘- -datadir=/usr/share’ ‘–includedir=/usr/include’ ‘–libdir=/usr/lib64’ ‘–libexe cdir=/usr/libexec’ ‘–localstatedir=/var’ ‘–sharedstatedir=/var/lib’ ‘–mandir= /usr/share/man’ ‘–infodir=/usr/share/info’ ‘–enable-plugin-freeipmi’ ‘–with-b undled-protobuf’ ‘–with-zlib’ ‘–with-math’ ‘–with-user=netdata’ ‘build_alias= x86_64-redhat-linux-gnu’ ‘host_alias=x86_64-redhat-linux-gnu’ ‘CFLAGS=-O2 -g -pi pe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=s sp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardene d-cc1 -m64 -mtune=generic’ ‘LDFLAGS=-Wl,-z,relro -specs=/usr/lib/rpm/redhat/red hat-hardened-ld’ ‘CXXFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptio ns -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -spe cs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic’ ‘PKG_CONFIG_PAT H=:/usr/lib64/pkgconfig:/usr/share/pkgconfig’
Install type: custom
Features:
dbengine: YES
Native HTTPS: YES
Netdata Cloud: YES
ACLK Next Generation: YES
ACLK Legacy: NO
TLS Host Verification: YES
Machine Learning: YES
Stream Compression: NO
Libraries:
protobuf: YES (bundled)
jemalloc: NO
JSON-C: YES
libcap: YES
libcrypto: YES
libm: YES
tcalloc: NO
zlib: YES
Plugins:
apps: YES
cgroup Network Tracking: YES
CUPS: NO
EBPF: NO
IPMI: YES
NFACCT: NO
perf: YES
slabinfo: YES
Xen: NO
Xen VBD Error Tracking: NO
Exporters:
AWS Kinesis: NO
GCP PubSub: NO
MongoDB: NO
