Unable to start netdata after installing latest nightly build
Unable to start netdata agent after installing
root@cnmaestro:/var/cache/netdata/dbengine# netdata -W buildinfo
Version: netdata v1.36.0-40-nightly
Configure options: ‘–build=x86_64-linux-gnu’ ‘–includedir=${prefix}/include’ ‘–mandir=${prefix}/share/man’ ‘–infodir=${prefix}/share/info’ ‘–disable-silent-rules’ ‘–libdir=${prefix}/lib/x86_64-linux-gnu’ ‘–libexecdir=${prefix}/lib/x86_64-linux-gnu’ ‘–disable-maintainer-mode’ ‘–prefix=/usr’ ‘–sysconfdir=/etc’ ‘–localstatedir=/var’ ‘–libdir=/usr/lib’ ‘–libexecdir=/usr/libexec’ ‘–with-user=netdata’ ‘–with-math’ ‘–with-zlib’ ‘–with-webdir=/var/lib/netdata/www’ ‘–disable-dependency-tracking’ ‘build_alias=x86_64-linux-gnu’ ‘CFLAGS=-g -O2 -fdebug-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security’ ‘LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro’ ‘CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2’ ‘CXXFLAGS=-g -O2 -fdebug-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security’
Install type: binpkg-deb
Binary architecture: x86_64
Packaging distro:
Features:
dbengine: YES
Native HTTPS: YES
Netdata Cloud: YES
ACLK: YES
TLS Host Verification: YES
Machine Learning: YES
Stream Compression: YES
Libraries:
protobuf: YES (system)
jemalloc: NO
JSON-C: YES
libcap: NO
libcrypto: YES
libm: YES
tcalloc: NO
zlib: YES
Plugins:
apps: YES
cgroup Network Tracking: YES
CUPS: YES
EBPF: YES
IPMI: YES
NFACCT: YES
perf: YES
slabinfo: YES
Xen: NO
Xen VBD Error Tracking: NO
Exporters:
AWS Kinesis: NO
GCP PubSub: NO
MongoDB: NO
Prometheus Remote Write: YES
Error log snippet:
2022-08-23 14:54:13: netdata INFO : MAIN : TIMEZONE: using the contents of /etc/timezone
2022-08-23 14:54:13: netdata INFO : MAIN : TIMEZONE: fixed as ‘Etc/UTC’
2022-08-23 14:54:13: netdata INFO : MAIN : SIGNAL: Not enabling reaper
2022-08-23 14:54:13: netdata INFO : MAIN : resources control: allowed file descriptors: soft = 1024, max = 524288
2022-08-23 14:54:13: netdata INFO : MAIN : Out-Of-Memory (OOM) score is already set to the wanted value 0
2022-08-23 14:54:13: netdata INFO : MAIN : Adjusted netdata scheduling policy to batch (3), with priority 0.
2022-08-23 14:54:13: netdata INFO : MAIN : Running with process scheduling policy ‘batch’, nice level 19
2022-08-23 14:54:13: netdata INFO : MAIN : netdata started on pid 64235.
2022-08-23 14:54:13: netdata INFO : MAIN : Initializing spawn client.
2022-08-23 14:54:13: netdata INFO : MAIN : Executing /usr/libexec/netdata/plugins.d/system-info.sh
Spawn server is up.
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_CONTAINER_OS_NAME=none
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_CONTAINER_OS_ID=none
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_CONTAINER_OS_ID_LIKE=none
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_CONTAINER_OS_VERSION=none
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_CONTAINER_OS_VERSION_ID=none
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_CONTAINER_OS_DETECTION=none
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_CONTAINER_IS_OFFICIAL_IMAGE=false
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_HOST_OS_NAME=Ubuntu
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_HOST_OS_ID=ubuntu
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_HOST_OS_ID_LIKE=debian
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_HOST_OS_VERSION=20.04.4 LTS (Focal Fossa)
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_HOST_OS_VERSION_ID=20.04
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_HOST_OS_DETECTION=/etc/os-release
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_HOST_IS_K8S_NODE=false
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_KERNEL_NAME=Linux
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_KERNEL_VERSION=5.11.0-46-generic
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_ARCHITECTURE=x86_64
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_VIRTUALIZATION=vmware
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_VIRT_DETECTION=systemd-detect-virt
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_CONTAINER=unknown
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_CONTAINER_DETECTION=systemd-detect-virt
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_LOGICAL_CPU_COUNT=4
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_VENDOR=GenuineIntel
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_MODEL=Intel(R) Xeon(R) Platinum 8280 CPU @ 2.70GHz
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_FREQ=2693000000
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_DETECTION=lscpu
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_TOTAL_RAM=8340815872
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_RAM_DETECTION=procfs
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_TOTAL_DISK_SIZE=192518553600
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_SYSTEM_DISK_DETECTION=sysfs
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_TYPE=unknown
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_INSTANCE_TYPE=unknown
2022-08-23 14:54:14: netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_INSTANCE_REGION=unknown
2022-08-23 14:54:14: netdata ERROR : MAIN : Failed to initialize database at /mnt/data/netdata/netdata-meta.db, due to “unable to open database file”
2022-08-23 14:54:14: netdata FATAL : netdata : Failed to initialize SQLite # : Success
2022-08-23 14:54:14: netdata INFO : MAIN : /usr/libexec/netdata/plugins.d/anonymous-statistics.sh ‘FATAL’ ‘netdata:netdata’ ‘0767@database/r:rrd_init /0’
2022-08-23 14:54:15: netdata ERROR : MAIN : Execution of anonymous statistics script returned http code 400.
2022-08-23 14:54:15: netdata INFO : MAIN : EXIT: netdata prepares to exit with code 1…
2022-08-23 14:54:15: netdata INFO : MAIN : /usr/libexec/netdata/plugins.d/anonymous-statistics.sh ‘EXIT’ ‘ERROR’ ‘-’
2022-08-23 14:54:16: netdata ERROR : MAIN : Execution of anonymous statistics script returned http code 400.
2022-08-23 14:54:16: netdata INFO : MAIN : EXIT: cleaning up the database…
2022-08-23 14:54:16: netdata INFO : MAIN : Cleaning up database [0 hosts(s)]…
2022-08-23 14:54:16: netdata INFO : MAIN : EXIT: removing netdata PID file ‘/var/run/netdata/netdata.pid’…
2022-08-23 14:54:16: netdata INFO : MAIN : EXIT: all done - netdata is now exiting - bye bye…
EOF found in spawn pipe.
Shutting down spawn server event loop.
Shutting down spawn server loop complete.
Hi @balajis ! Welcome to Netdata !
Looks like something off with the installation… How did you install? Kickstart script ?
Can you try to re-install ? You can try by passing the --reinstall flag to the kickstart script.
Hi @Manolis_Vasilakis ,
I have installed through kickstart script. Even reinstall doesn’t work. Could you please help on this?
Sure! Can you please post the output (or maybe upload it somewhere) of the kickstart script?
Do you get the same errors when you try to run the agent?
