As mentioned in the title, I wanted to ask if it is possible to use attributes to change the font size of d3pie charts.
Also I would like to remove the header (e.g. Apps CPU Time (100% = 1 core) (apps.cpu)).
Best regards
e_mps
Best regards
e_mps
Hello @e_mps ,
You can customize all the custom dashboard charts by passing data attributes, for reference you can check the code here - unfortunately, the documentation is not covering all the options for all the chart libraries available.
Now, regarding your 2 questions:
I will start with the second one about the title, you can set data- d3pie-title="" to set it to empty, thus remove it.
Changing font sizes in general, can be done for multiple elements.
data-d3pie-title-fontsize (code)data-d3pie-subtitle-fontsize (code)data-d3pie-footer-fontsize (code)data-d3pie-labels-mainLabel-fontsize,data-d3pie-labels-percentage-fontsize anddata-d3pie-labels-value-fontsizeHopefully I got you covered
, if not or you have any other questions do not hesitate to come back.
Thank you,
J.
Hello @novykh,
thank you very much for the quick reply. This is exactly what I was looking for.
If you already offer your help so kindly. Is it possible to move the chart inside the div container to the right? I already found the function “pieCenterOffset,” however I don’t know how to include it into my code. Obviosly it doesn’t work in CSS.
I also tried :
I’m sorry if I make obvious mistakes, but I’m relatively new in this field and the project is mainly for learning.
Best regards
M.
Hey @e_mps,
So apparently you cannot change those values, since they are statically set.
canvasPadding: {
top: 5,
right: 5,
bottom: 5,
left: 5
pieCenterOffset: {
x: 0,
y: 0
and there is no way to pass a data attribute to override them at the moment. Of course this can change, either on your local copy of netdata or open a PR on the netdata/dashboard repo ![]()
Here’s a quick demonstration of such change:
pieCenterOffset: {
x: NETDATA.dataAttribute(state.element, 'd3pie-misc-pieCenterOffset-x', 0),
y: NETDATA.dataAttribute(state.element, 'd3pie-misc-pieCenterOffset-y', 0),
We always welcome new contributors, so feel free to open a PR - we are kind reviewers mostly I promise ![]()
Another approach, is to wrap the chart-div with another one with your own styles, that way you can just add padding and/or any other css rule you’d like. But I’m not sure whether that would satisfy your needs, since I don’t know the exact requirements of your project.
Best,
J.
