Custom Dashboard HTML Page using /api/v2
Hi, first of all thanks for this amazing project!
Currently, I’ve been experimenting with custom dashboard HTML pages as described here Custom dashboards | Learn Netdata. Is it possible to use api v2 to build these custom dashboard HTML pages?
Thanks and best regards!
Hi @boasmeier ,
Thank your for the feedback.
Unfortunately that is a feature that wasn’t revisited when the api v2 and the new UI were released.
At the moment, we don’t have plans to make it available.
Regards,
Hugo
Hello @hugo , since the API v1 is mentioned as EOL, does it mean you no longer plan to offer custom dashboards, such as the ones that could be embedded using HTML code? outside of those that can be created on the Netdata’s rooms and cloud? Any plan to make them available again or is the strategy to push for using Netdata local agent view using local-custom-dashboard?
Such a shame that we are now forced to use the cloud to do custom dashboards using the v2 api.
its unfortunate that there is still no alternative for this, as it was one reason why we choose net-data and we spent a lot of time building different dashboards into our apps.
