I can’t see any docker charts on v1.38.0-153-nightly
before it worked OK
Hi @ben is this still an issue for you?
Can you provide a little bit more info about your system and installation.
# Linux
uname -a; grep -HvE "^#|URL" /etc/*release
# BSD
uname -a; uname -K
# macOS
uname -a; sw_vers
netdata -W buildinfo
# If get "netdata: command not found", try (required running Netdata)
$(ps aux | grep -m1 -E -o "[a-zA-Z/]+netdata ") -W buildinfo
Yes still broken.
Linux wololo 5.15.0-56-generic #62-Ubuntu SMP Tue Nov 22 19:54:14 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
/etc/lsb-release:DISTRIB_ID=Ubuntu
/etc/lsb-release:DISTRIB_RELEASE=22.04
/etc/lsb-release:DISTRIB_CODENAME=jammy
/etc/lsb-release:DISTRIB_DESCRIPTION="Ubuntu 22.04.1 LTS"
/etc/os-release:PRETTY_NAME="Ubuntu 22.04.1 LTS"
/etc/os-release:NAME="Ubuntu"
/etc/os-release:VERSION_ID="22.04"
/etc/os-release:VERSION="22.04.1 LTS (Jammy Jellyfish)"
/etc/os-release:VERSION_CODENAME=jammy
/etc/os-release:ID=ubuntu
/etc/os-release:ID_LIKE=debian
/etc/os-release:UBUNTU_CODENAME=jammy
Version: netdata v1.38.0-159-nightly
Configure options: '--build=x86_64-linux-gnu' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--disable-option-checking' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--libexecdir=${prefix}/lib/x86_64-linux-gnu' '--disable-maintainer-mode' '--prefix=/usr' '--sysconfdir=/etc' '--localstatedir=/var' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--with-user=netdata' '--with-math' '--with-zlib' '--with-webdir=/var/lib/netdata/www' '--disable-dependency-tracking' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -ffile-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -ffile-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security'
Install type: binpkg-deb
Binary architecture: x86_64
Packaging distro:
Features:
dbengine: YES
Native HTTPS: YES
Netdata Cloud: YES
ACLK: YES
TLS Host Verification: YES
Machine Learning: YES
Stream Compression: YES
Libraries:
protobuf: YES (system)
jemalloc: NO
JSON-C: YES
libcap: NO
libcrypto: YES
libm: YES
tcalloc: NO
zlib: YES
Plugins:
apps: YES
cgroup Network Tracking: YES
CUPS: YES
EBPF: YES
IPMI: YES
NFACCT: YES
perf: YES
slabinfo: YES
Xen: NO
Xen VBD Error Tracking: NO
Exporters:
AWS Kinesis: NO
GCP PubSub: NO
MongoDB: NO
Prometheus Remote Write: YES
Debug/Developer Features:
Trace Allocations: NO
Hi, @ben. What are docker stats/charts? What charts are you referring to?
Well like ~10 days or so ago I could see:
- docker container count (both running and offline)
- docker images count
e.t.c
Still doesn’t work. I have auto-updates on.
Netdata Agent:
v1.38.0-224-nightly
Try to run the plugin in debug mode.
[ DEBUG ] build[manager] build.go:164 received config group ('/usr/lib/netdata/conf.d/go.d/docker_engine.conf'): 1 jobs (added: 1, removed: 0)
[ DEBUG ] build[manager] build.go:313 building docker_engine[local] job, config: map[__provider__:file reader __source__:/usr/lib/netdata/conf.d/go.d/docker_engine.conf autodetection_retry:0 module:docker_engine name:local priority:70000 update_every:1 url:http://127.0.0.1:9323/metrics]
[ ERROR ] docker_engine[local] docker_engine.go:107 Get "http://127.0.0.1:9323/metrics": dial tcp 127.0.0.1:9323: connect: connection refused
[ ERROR ] docker_engine[local] job.go:205 check failed
These are docker_engine log lines, not docker. Can you try again, please?
[ ERROR ] docker[local] docker.go:73 Error response from daemon: client version 1.42 is too new. Maximum supported API version is 1.41
[ ERROR ] docker[local] job.go:205 check failed
Ok, thanks. I think I see what is happening, fixed in docker: add api version negotiation. The fix will be in the nightly release early next week.
