I would like to prevent netdata from sending the below metrics:
netdata_cpu_interrupts_interrupts_persec_average
netdata_cpu_interrupts_total
So I add this configuration to the netdata.conf file:
[backend]
send charts matching = !cpu.*_interrupts *
But I still see the metrics in the Prometheus endpoint api/v1/allmetrics?format=prometheus_all_hosts:
netdata_cpu_interrupts_interrupts_persec_average{chart="cpu.cpu0_interrupts",family="interrupts",dimension="i8042_1",instance="netdata-test-01"} 0.0000000 1618639870000
ilyam8
2
Hi @Yashar_Nesabian
That is a bug, send charts matching doesn’t work when using [backend].
We suggest to switch to exporting engine
# exporting.conf
[pc netdata]# cat exporting.conf
[exporting:global]
enabled = no
# send configured labels = yes
# send automatic labels = no
# update every = 10
[prometheus:exporter]
# data source = average
# send names instead of ids = yes
# send charts matching = *
Hey @ilyam8,
Since exporting is the new backends, is there a way to let the user know that they are using a deprecated feature?
Relevant to this, why do we allow users to use backends?
Thanks @ilyam8 this solved the problem
ilyam8
5
There were several bugs:
- when only backends
send charts matching configured
- when both backends and exporting
Fixed in Backend chart filtering backward compatibility fix by vlvkobal · Pull Request #11002 · netdata/netdata · GitHub
But why do we still have legacy support for [backend] in the first place @ilyam8 ?
We are planning to remove it completely soon.
Awesome, thanks! I was really really curious
