Major release to improve the way to interact with Custom Dashboards! ![]()
With this release, you will be able to:
- Drag and drop charts from Metrics or Single Node views to custom dashboards.
- Drag and drop right away to a new dashboard (plus button/tab on the navigation bar)
- Redesigned text cards in dashboards
- Rename charts in custom dashboards.
- Use new chart types:: Bar, Circle, Gauge, Pie, Value, Group boxes
Even though this is still an early release, the overall experience and usability have improved in a major way and (hopefully) will bring a lot of value to you.
Enjoy it while we keep ironing out some loose ends and add more features!
