ebpf plugin installation failing
I’ve Netdata running as container, on a Linux Machine. I was interested in installing ebpf metrics to monitor network stack for apps_group. I mounted ebpf.d.conf to /etc/netdata and also netdata.conf to /etc/netdata, since netdata.conf did not contain ebpf plugin by default when checked in localhost:19999/netdata.conf. How can I enable ebpf plugin to monitor metrics of apps_group?
  1. Monitor, troubleshoot, and debug applications with eBPF metrics | Learn Netdata
  2. netdata/src/collectors/ebpf.plugin/README.md at master · netdata/netdata · GitHub
netdata -W buildinfo:
Packaging:
Netdata Version ____________________________________________ : v1.47.4
Installation Type __________________________________________ : oci
Package Architecture _______________________________________ : aarch64
Package Distro _____________________________________________ : unknown
Configure Options __________________________________________ : dummy-configure-command
Default Directories:
Operating System:
Kernel Version _____________________________________________ : 5.15.136-tegra
Operating System ___________________________________________ : Ubuntu
Operating System ID ________________________________________ : ubuntu
Operating System ID Like ___________________________________ : debian
Operating System Version ___________________________________ : 22.04.4 LTS (Jammy Jellyfish)
Operating System Version ID ________________________________ : 12
Detection __________________________________________________ : /host/etc/os-release
Hardware:
CPU Cores __________________________________________________ : 8
CPU Frequency ______________________________________________ : 1984000000
RAM Bytes __________________________________________________ : 16417783808
Disk Capacity ______________________________________________ : 256060514304
CPU Architecture ___________________________________________ : aarch64
Virtualization Technology __________________________________ : unknown
Virtualization Detection ___________________________________ : none
Container:
Container __________________________________________________ : lxc
Container Detection ________________________________________ : containerenv
Container Operating System _________________________________ : Debian GNU/Linux
Container Operating System ID ______________________________ : debian
Container Operating System ID Like _________________________ : unknown
Container Operating System Version _________________________ : 12 (bookworm)
Container Operating System Version ID ______________________ : 12
Container Operating System Detection _______________________ : /etc/os-release
Features:
Database Engines:
dbengine (compression) _____________________________________ : YES (zstd lz4)
Connectivity Capabilities:
Libraries:
libmnl (library for working with netfilter) ________________ : YES
Plugins:
cups (monitor printers and print jobs) _____________________ : NO
ebpf (monitor system calls) ________________________________ : NO
nfacct (gather netfilter accounting) _______________________ : NO
Xen ________________________________________________________ : NO
Exporters:
Debug/Developer Features:
ebpf.d.conf file looks like:
ebpf load mode = entry
apps = yes
cgroups = no
update every = 5
pid table size = 32768
btf path = /sys/kernel/btf/
maps per core = yes
lifetime = 3
[ebpf programs]
cachestat = no
dcstat = no
disk = no
fd = no
filesystem = no
hardirq = no
mdflush = no
mount = no
oomkill = no
process = no
shm = no
socket = no
softirq = no
sync = no
swap = no
vfs = no
network connections = yes
netdata.conf looks like:
[plugins]
ebps = yes
Netdata version:
Netdata Agent:
v1.47.4
System Info:
Type:lxc
O/S version:Ubuntu, 22.04.4 LTS (Jammy Jellyfish)
Architecture:aarch64
Kernel:Linux, 5.15.136-tegra
  1. Plugins section contain ebpf when I visit localhost:19999/netdata.conf
    [plugins]
    ebpf = yes
  2. ebpf metrics charts appear under Applications (apps_group).
What I observed
  1. The [plugins] section in netdata.conf showed this:
    [plugins]
    option ‘ebpf’ is not used.
    ebpf = yes
  2. No ebpf metrics charts observed under Applications (apps_group) section.
Hello @meghnamscs ,
When I was developing the plugin, we had an internal discussion, and I was informed that running a plugin within a container requires specific configurations for the container environment. Additionally, at that time, the Alpine distribution did not enable the ebpf syscall by default, which could also impact functionality.
If you run the plugin directly on your host machine, it should work as expected. However, unless there have been updates or changes on the container side since then, it is still not feasible to run the plugin inside a container without making the necessary adjustments.
Please let me know if you need further clarification.
Best regards,
Thiago
