Failed to write claiming configuration : command not found
Hello!
I’m trying to install netdata agent on fresh new debian 12 VPS using the kickstart.sh snippet.
If I try to run the wget [.....] snippet using a normal user (not root), the installation completes with a warning:
[/tmp/netdata-kickstart-CKpNZWeafd]$ sudo reload-claiming-state
sudo: : command not found
FAILED
WARNING Failed to write claiming configuration. This usually means you do not have permissions to access the configuration directory.
If I try to run the wget [...] snipped using root, I do not get any warning and I noticed that the command above is different:
[/tmp/netdata-kickstart-vvNCshGN0C]# /usr/sbin/netdatacli reload-claiming-state
As you can see, the /usr/sbin/netdatacli part is present only when the script is run with root
So, I open the script file and I’ve noticed these lines
  # more lines
  netdatacli="$(command -v netdatacli)"
  # more lines
  if [ -z "${NETDATA_CLAIM_NORELOAD}" ]; then
    run_as_root "${netdatacli}" reload-claiming-state || return 1
  fi
So the problem must be with command -v netdatacli
In fact, when I run command -v netdatacli with my normal user I get nothing, when I run it as root I get /usr/sbin/netdatacli
That’s because my normal user does not have /usr/sbin in its PATH, while root user has it.
So, my question is: is this a bug in the netdata installation script? Or, should I always run the installation script as root ? The documentation does not say that you have to run it as root though, and it supports sudo so I suppose this should work even when it is run as a normal user
It’s arguably a matter of a design issue in Debian (the /bin versus /sbin distinction has essentially no meaning these days, Debian and Ubuntu just choose to hold on to the historical differentiation).
But it also is a bug in our code, we should be adding /sbin and /usr/sbin to the search path regardless of UID, and we should also be checking to make sure we actually found netdatacli before trying to invoke it.
I’ve opened Fix issues with $PATH and netdatacli detection. by Ferroin · Pull Request #19371 · netdata/netdata · GitHub to fix this. Once that’s merged, it should go live relatively quickly.
Thank you very for the fast fix!
