Tried uninstalling netdata, it failed
Hi guys,
I always have issues with updating NetData on one of my instances and while I manage to update this time, but the version didn’t update in the cloud dashboard. Then I did a system reboot and now it’s offline.
When I did a service status it says
● netdata.service
Loaded: masked (/dev/null; bad)
Active: inactive (dead)
But it also said this both before the update and the reboot. While the at the cloud dashboard everything was looking fine both times. The instance was monitored well.
So I thought I should just do a complete reinstall, with first cleaning everything NetData related. But it failed.
root@build:~# wget -O /tmp/netdata-kickstart.sh https://my-netdata.io/kickstart.sh && sh /tmp/netdata-kickstart.sh --uninstall
–2023-10-25 11:26:31-- https://my-netdata.io/kickstart.sh
Resolving my-netdata.io (my-netdata.io)… 104.21.13.159, 172.67.156.192, 2606:4700:3031::6815:d9f, …
Connecting to my-netdata.io (my-netdata.io)|104.21.13.159|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘/tmp/netdata-kickstart.sh’
/tmp/netdata-kickstart.sh [ <=> ] 82.99K --.-KB/s in 0.002s
2023-10-25 11:26:31 (42.9 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [84980]
— Using /tmp/netdata-kickstart-EJL3CjGIVp as a temporary directory. —
— Checking for existing installations of Netdata… —
[/tmp/netdata-kickstart-EJL3CjGIVp]# test -x /usr/local/usr/libexec/netdata/netdata-uninstaller.sh
FAILED
— Downloading netdata-uninstaller … —
[/tmp/netdata-kickstart-EJL3CjGIVp]# /usr/bin/curl --fail -q -sSL --connect-timeout 10 --retry 3 --output /tmp/netdata-kickstart-EJL3CjGIVp/netdata-uninstaller.sh https://raw.githubusercontent.com/netdata/netdata/master/packaging/installer/netdata-uninstaller.sh
OK
[/tmp/netdata-kickstart-EJL3CjGIVp]# /tmp/netdata-kickstart-EJL3CjGIVp/netdata-uninstaller.sh --yes
/tmp/netdata-kickstart-EJL3CjGIVp/netdata-uninstaller.sh: 711: .: Can’t open /etc/netdata/.environment
Wed Oct 25 11:26:31 CEST 2023 : FATAL: netdata-uninstaller.sh: FAILED TO UNINSTALL NETDATA: Failed to completely remove Netdata from this system.
FAILED
Finished uninstalling the Netdata Agent.The following non-fatal warnings or errors were encountered:
  • Command “test -x /usr/local/usr/libexec/netdata/netdata-uninstaller.sh” failed with exit code 1.
  • Command “/tmp/netdata-kickstart-EJL3CjGIVp/netdata-uninstaller.sh --yes” failed with exit code 1.
[/root]# rm -rf /tmp/netdata-kickstart-EJL3CjGIVp
OK
The installation type is:
root@build:~# netdata -W buildinfo | grep -E ‘Installation Type|Install type:’
Installation Type __________________________________________ : kickstart-static
Here are (possibly) all netdata related folders on the drive:
root@build:~# find / -d -name netdata
/usr/lib/netdata
/usr/local/bin/netdata
/etc/logrotate.d/netdata
/etc/init.d/netdata
/etc/default/netdata
/etc/netdata
/opt/netdata/usr/libexec/netdata
/opt/netdata/usr/lib/netdata/system/freebsd/rc.d/netdata
/opt/netdata/usr/lib/netdata/system/initd/init.d/netdata
/opt/netdata/usr/lib/netdata/system/lsb/init.d/netdata
/opt/netdata/usr/lib/netdata/system/openrc/init.d/netdata
/opt/netdata/usr/lib/netdata/system/openrc/conf.d/netdata
/opt/netdata/usr/lib/netdata/system/logrotate/netdata
/opt/netdata/usr/share/netdata
/opt/netdata/bin/srv/netdata
/opt/netdata/bin/netdata
/opt/netdata/etc/netdata
/opt/netdata/var/lib/netdata
/opt/netdata/var/cache/netdata
/opt/netdata/var/log/netdata
/opt/netdata
/var/lib/netdata
/var/cache/netdata
/var/log/netdata
Could you help me out what’s happening? Maybe there are two netdatas conflicting each other? Thanks in advance!
bump :frowning: Could someone suggest me something? Thanks in advance!
Hello @Tudvari and sorry for missing your post.
Could you please share the out of ps aux | grep netdata
plus if you don’t care about the data of this Agent I would recommend to;
EDITED:
sh /opt/netdata/usr/libexec/netdata/netdata-uninstaller.sh --env /opt/netdata/etc/netdata/.environment --yes
and then try to run the kickstart with `–uninstall`` option
The rationale is; if two netdata deployments are there first uninstall the /opt/netdat and then the systemd wide
But we need to find the root cause of this, you provided a details description, but I need you to remember what actions you did in the node from the very beginning. when you noticed the problem and what actions you did then. . .
No problem, thanks in advance for all the help! :slight_smile:
The ps aux grep returned only the grep itself.
Sadly I don’t remember the details anymore. :\
EDIT: running the uninstall right now
edited, be aware of what it prompts you to clean up, not sure if this environment file is tampered somehow. . .
We want to delete only any netdata under /opt/netdata and or the system wide elements (services, logrotate etc)
I ran your line, I said “yes” to all prompt because they all seemed reasonable.
After that I tried running the kickstart with ‘–uninstall’ and it said the following… is this the expected?
–2023-11-15 16:21:33-- https://my-netdata.io/kickstart.sh
Resolving my-netdata.io (my-netdata.io)… <…>, …
Connecting to my-netdata.io (my-netdata.io)|<…>|:443… connected.
/tmp/netdata-kickstart.sh [ <=> ] 82.82K --.-KB/s in 0.006s
2023-11-15 16:21:33 (14.0 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [84811]
— Using /tmp/netdata-kickstart-4eqMRzqASc as a temporary directory. —
[/tmp/netdata-kickstart-4eqMRzqASc]# test -x /usr/libexec/netdata/netdata-uninstaller.sh
FAILED
[/tmp/netdata-kickstart-4eqMRzqASc]# /usr/bin/curl --fail -q -sSL --connect-timeout 10 --retry 3 --output /tmp/netdata-kickstart-4eqMRzqASc/netdata-uninstaller.sh https://raw.githubusercontent.com/netdata/netdata/master/packaging/installer/netdata-uninstaller.sh
OK
[/tmp/netdata-kickstart-4eqMRzqASc]# /tmp/netdata-kickstart-4eqMRzqASc/netdata-uninstaller.sh --yes
/tmp/netdata-kickstart-4eqMRzqASc/netdata-uninstaller.sh: 711: .: Can’t open /etc/netdata/.environment
Wed Nov 15 16:21:34 CET 2023 : FATAL: netdata-uninstaller.sh: FAILED TO UNINSTALL NETDATA: Failed to completely remove Netdata from this system.
FAILED
  • Command “test -x /usr/libexec/netdata/netdata-uninstaller.sh” failed with exit code 1.
  • Command “/tmp/netdata-kickstart-4eqMRzqASc/netdata-uninstaller.sh --yes” failed with exit code 1.
[/root]# rm -rf /tmp/netdata-kickstart-4eqMRzqASc
OK
ls -la /etc/netdata & ls -la /etc/default/netdata?
Q: this a BSD variant, did you installed netdata via ports in the first place, could you recall that???
Sorry, I remember that there were some issues in the past regarding one of our instances’ netdata installation but nothing in particular.
root@build:~# ls -la /etc/netdata & ls -la /etc/default/netdata
[1] 4468
total 20
drwxr-xr-x 2 root root 4096 Dec 15 2022 .
drwxr-xr-x 90 root root 4096 Nov 15 16:28 …
-rwxr-xr-x 1 root root 2045 Jun 10 2022 edit-config
-rw-r–r-- 1 root root 69 Jun 10 2022 .install-type
-rw-r–r-- 1 root root 533 Jun 10 2022 netdata.conf
-rw-r–r-- 1 root root 84 Jun 10 2022 /etc/default/netdata
[1]+ Done ls -la /etc/netdata
root@build:~# cat /etc/netdata/.install-type
INSTALL_TYPE=‘binpkg-deb’
PREBUILT_ARCH=‘x86_64’
PREBUILT_DISTRO=’ ’
Ok what’s your platform? try something like uname -srm
root@build:~# uname -srm
Linux 4.9.0-19-amd64 x86_64
also try an apt purge netdata, why do I believe it was a BSD variant? :man_shrugging:
root@build:~# apt purge netdata
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following packages were automatically installed and are no longer required:
libnetfilter-acct1 libprotobuf10 libsnappy1v5
Use ‘apt autoremove’ to remove them.
The following packages will be REMOVED:
netdata*
0 upgraded, 0 newly installed, 1 to remove and 1 not upgraded.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database … 120795 files and directories currently installed.)
Purging configuration files for netdata (1.35.1) …
dpkg: warning: while removing netdata, directory ‘/var/log/netdata’ not empty so not removed
dpkg: warning: while removing netdata, directory ‘/var/lib/netdata’ not empty so not removed
dpkg: warning: while removing netdata, directory ‘/var/cache/netdata’ not empty so not removed
dpkg: warning: while removing netdata, directory ‘/usr/lib/netdata/conf.d/health.d’ not empty so not removed
Processing triggers for systemd (232-25+deb9u14) …
force delete the directories, that the dpkg couldn’t remove.
and I think you are ready to re-deploy, keep in mind stick with --static-only installation for this node, it’s debian 9 which we don’t support native packages atm
Removed them, and then ran the kickstart script with --static-only flag .
However when I tried to claim it, it said the following:
root@build:~# wget -O /tmp/netdata-kickstart.sh https://my-netdata.io/kickstart.sh && sh /tmp/netdata-kickstart.sh --nightly-channel --claim-token <…> --claim-rooms <…> --claim-url https://app.netdata.cloud
–2023-11-15 17:01:04-- https://my-netdata.io/kickstart.sh
Connecting to my-netdata.io (my-netdata.io)<…>|:443… connected.
/tmp/netdata-kickstart.sh [ <=> ] 82.82K --.-KB/s in 0.007s
2023-11-15 17:01:04 (11.9 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [84811]
— Using /tmp/netdata-kickstart-sPpTdLmMiq as a temporary directory. —
WARNING Found an existing netdata install at /usr/local, but could not determine the install type. Usually this means you installed Netdata through your distribution’s regular package repositories or some other unsupported method.
Attempting to update an existing install with an unknown installation type is not officially supported. It may work, but it also might break your system. If you just want to claim this install, you should re-run this command with the --claim-only option instead. Are you sure you want to continue? [y/n]
Probably we left behind something, please
  1. find any netdata dir in the system
  2. what’s the output of: ps aux | grep netdata
  3. what’s the output of: systemctl status netdata
  4. what’s the output of ./opt/netdata/usr/sbin/netdata -W buildinfo
  5. what\s the output of which netdata (if you don’t have exported the /opt/netdata/usr/sbin in your paths, it should report nothing)
So I ran that netdata-uninstaller.sh in the exact way you mentioned earlier, said yes to everything and then I did a reboot.
Here are the checks:
root@build:~# ps aux | grep netdata
root 4333 0.0 0.0 12780 964 pts/0 S+ 11:02 0:00 grep netdata
root@build:~# systemctl status netdata
Unit netdata.service could not be found.
root@build:~# ./opt/netdata/usr/sbin/netdata -W buildinfo
-bash: ./opt/netdata/usr/sbin/netdata: No such file or directory
root@build:~# which netdata
root@build:~# sudo find / -type d -name ‘netdata’ 2>/dev/null
root@build:~# sudo find / -type f -name ‘netdata’ 2>/dev/null
/netdata-updater.log.lhcyQN
/netdata-updater.log.GmG2EP
/netdata-updater.log.WUIIT1
/netdata-updater.log.jDaqH0
/netdata-updater.log.eAJnr7
/netdata-updater.log.HPkURP
/etc/apt/trusted.gpg.d/netdata-repoconfig-archive-keyring.gpg
/etc/apt/trusted.gpg.d/netdata-archive-keyring.gpg
/etc/apt/trusted.gpg.d/netdata-edge-archive-keyring.gpg
/etc/apt/sources.list.d/netdata-edge.list
/etc/apt/sources.list.d/netdata.list
/netdata-updater.log.eFYtij
/netdata-updater.log.LFLcZe
/netdata-updater.log.mMOsSw
/netdata-updater.log.WKzOWc
/var/lib/apt/lists/packagecloud.io_netdata_netdata-edge_debian_dists_stretch_InRelease
/var/lib/apt/lists/packagecloud.io_netdata_netdata-repoconfig_debian_dists_stretch_main_binary-amd64_Packages
/var/lib/apt/lists/packagecloud.io_netdata_netdata_debian_dists_stretch_InRelease
/var/lib/apt/lists/packagecloud.io_netdata_netdata_debian_dists_stretch_Release.gpg
/var/lib/apt/lists/packagecloud.io_netdata_netdata-edge_debian_dists_stretch_main_binary-amd64_Packages
/var/lib/apt/lists/packagecloud.io_netdata_netdata-repoconfig_debian_dists_stretch_InRelease
/var/lib/apt/lists/packagecloud.io_netdata_netdata_debian_dists_stretch_main_binary-amd64_Packages
/var/lib/dpkg/info/netdata-repo-edge.list
/var/lib/dpkg/info/netdata-repo.list
/var/cache/apt/archives/netdata_1.35.1_amd64.deb
/var/cache/apt/archives/netdata_1.34.1_amd64.deb
/var/cache/apt/archives/netdata-repo_1-1_all.deb
/var/cache/apt/archives/netdata-repo-edge_1-2_all.deb
/var/cache/apt/archives/netdata_1.33.1-236-nightly_amd64.deb
/var/cache/apt/archives/netdata-repo-edge_1-1_all.deb
Am I ready to try installing a static-only build again?
Ok proceed with the following steps:
  1. Delete the outdated sources of netdata from the apt package manager (just for completeness)
  2. Check the output of thedpkg-query --show --showformat '${Status}' "netdata", Probably it advertises that you have a netdata package, you need to get rid of it
  3. Most of the other stuff can be gone with an apt-get clean
Done, and it says
dpkg-query: no packages found matching netdata
File search says:
root@build:/# sudo find / -type f -name '*netdata*' 2>/dev/null
Should I reinstall it now?
dpkg-query --show --showformat '${Status}' "netdata" ,
Kickstart performs the same check and package installation under /usr/local is returned
I know that you saw a lot of find results but, could you verify that nothing related to netdata /usr/local?
Check system-wide with
sudo find / -type f -iname '*netdata*'
EDITED: Please share the output before run the kickstart again
If no netdata residues are there, do the following run the kickstart with --static-only and --reinstall-even-if-unsafe
Sure, here are the results:
root@build:/# dpkg-query --show --showformat '${Status}' "netdata"
root@build:/# sudo find / -type f -iname '*netdata*'
