Environment: Debian 11
Netdata: v1.38.0 from netdata repo
I have been trying to integrate SNMP monitoring of a CyberPower PDU81002 based on the MIB definition provided for this device. I have successfully used snmpwalk and other mib browsers to correctly identify the OID values I am interested in.
Since Debian 11 does not yet package the go.d plugin, and the node.d.plugin is now deprecated, I have downloaded the latest netdata debian package from the netdata repo, although I’ll point out that everything I’m about to explain was also problematic using the node plugin.
This device has 8 outlets for which power utilization can be measured in both amps and watts. I ultimately want to monitor all 8 outlets as well as some other statistics (on or off, etc), but I am starting with one outlet and these two oids. My go.d/snmp.conf is as follows:
jobs:
- name: cps
hostname: "10.10.10.240"
community: public
update_every: 1
max_request_size: 150
options:
version: 2
charts:
- id: "outlet_status_load"
units: "amps"
type: "area"
dimensions:
- name: "cabinet"
oid: "1.3.6.1.4.1.3808.1.1.6.6.2.4.1.6.8"
algorithm: "incremental"
multiplier: 1
divisor: 1
- id: "outlet_status_active_power"
units: "watts"
type: "area"
dimensions:
- name: "cabinet"
oid: "1.3.6.1.4.1.3808.1.1.6.6.2.4.1.7.8"
multiplier: 1
divisor: 1
When I run /usr/libexec/netdata/plugins.d/go.d.plugin -d I can see it successfully read the two oids correctly at every interval:
BEGIN 'snmp_cps.outlet_status_load' 999555
SET 'cabinet' = 8
END
BEGIN 'snmp_cps.outlet_status_active_power' 999555
SET 'cabinet' = 50
END
which repeats every “tick” interval. (full log attached).
I’ve turned off every other metric in netdata.conf (also attached) and written a custom dashboard to just expose these charts (cps.html, attached)
I get occasional peaks on the amp chart and very isolated peaks on the watt chart, but neither values are correct, or consistent. The amperage load on the outlet being measured is consistently 8 (measured in tenth-amps) and the power in watts is consistently 50 (measured in watts).
What I want to see is a flat line at 8 and 50 so long as the load/power doesn’t fluctuate, and if it does fluctuate, I’d like the graph to show this. I do not want a scissor peak between a value and 0, and I do not want the wrong values! I’ve attached a screen shot of what my custom dashboard shows.
If additional log snippets or configuration is useful, please ask.
Thanks,
-brmiller
go.d.plugin-debug.txt
[ DEBUG ] main[main] main.go:113 plugin: name=go.d, version=v0.50.0
[ DEBUG ] main[main] main.go:115 current user: name=root, uid=0
[ INFO ] main[main] agent.go:136 instance is started
[ INFO ] main[main] setup.go:42 loading config file
[ INFO ] main[main] setup.go:50 looking for 'go.d.conf' in [/etc/netdata /usr/lib/netdata/conf.d]
[ INFO ] main[main] setup.go:57 found '/etc/netdata/go.d.conf
[ INFO ] main[main] setup.go:64 config successfully loaded
[ INFO ] main[main] agent.go:140 using config: enabled 'true', default_run 'true', max_procs '0'
[ INFO ] main[main] setup.go:69 loading modules
[ INFO ] main[main] setup.go:83 'openvpn_status_log' module disabled in the config file
[ INFO ] main[main] setup.go:83 'ping' module disabled in the config file
[ INFO ] main[main] setup.go:83 'zookeeper' module disabled in the config file
[ INFO ] main[main] setup.go:83 'proxysql' module disabled in the config file
[ INFO ] main[main] setup.go:83 'traefik' module disabled in the config file
[ INFO ] main[main] setup.go:83 'whoisquery' module disabled in the config file
[ INFO ] main[main] setup.go:83 'coredns' module disabled in the config file
[ INFO ] main[main] setup.go:83 'freeradius' module disabled in the config file
[ INFO ] main[main] setup.go:83 'lighttpd' module disabled in the config file
[ INFO ] main[main] setup.go:83 'mongodb' module disabled in the config file
[ INFO ] main[main] setup.go:83 'nginxvts' module disabled in the config file
[ INFO ] main[main] setup.go:83 'pgbouncer' module disabled in the config file
[ INFO ] main[main] setup.go:83 'pihole' module disabled in the config file
[ INFO ] main[main] setup.go:83 'dnsmasq' module disabled in the config file
[ INFO ] main[main] setup.go:79 'example' module disabled by default, should be explicitly enabled in the config
[ INFO ] main[main] setup.go:83 'filecheck' module disabled in the config file
[ INFO ] main[main] setup.go:83 'haproxy' module disabled in the config file
[ INFO ] main[main] setup.go:83 'nginx' module disabled in the config file
[ INFO ] main[main] setup.go:83 'vsphere' module disabled in the config file
[ INFO ] main[main] setup.go:83 'web_log' module disabled in the config file
[ INFO ] main[main] setup.go:83 'couchdb' module disabled in the config file
[ INFO ] main[main] setup.go:83 'wmi' module disabled in the config file
[ INFO ] main[main] setup.go:83 'cassandra' module disabled in the config file
[ INFO ] main[main] setup.go:83 'chrony' module disabled in the config file
[ INFO ] main[main] setup.go:83 'dns_query' module disabled in the config file
[ INFO ] main[main] setup.go:83 'docker_engine' module disabled in the config file
[ INFO ] main[main] setup.go:83 'powerdns_recursor' module disabled in the config file
[ INFO ] main[main] setup.go:83 'postgres' module disabled in the config file
[ INFO ] main[main] setup.go:83 'vernemq' module disabled in the config file
[ INFO ] main[main] setup.go:83 'wireguard' module disabled in the config file
[ INFO ] main[main] setup.go:83 'cockroachdb' module disabled in the config file
[ INFO ] main[main] setup.go:83 'couchbase' module disabled in the config file
[ INFO ] main[main] setup.go:83 'logstash' module disabled in the config file
[ INFO ] main[main] setup.go:79 'systemdunits' module disabled by default, should be explicitly enabled in the config
[ INFO ] main[main] setup.go:83 'tengine' module disabled in the config file
[ INFO ] main[main] setup.go:83 'consul' module disabled in the config file
[ INFO ] main[main] setup.go:83 'dnsdist' module disabled in the config file
[ INFO ] main[main] setup.go:83 'phpfpm' module disabled in the config file
[ INFO ] main[main] setup.go:83 'redis' module disabled in the config file
[ INFO ] main[main] setup.go:83 'vcsa' module disabled in the config file
[ INFO ] main[main] setup.go:83 'x509check' module disabled in the config file
[ INFO ] main[main] setup.go:83 'docker' module disabled in the config file
[ INFO ] main[main] setup.go:83 'lighttpd2' module disabled in the config file
[ INFO ] main[main] setup.go:83 'nginxplus' module disabled in the config file
[ INFO ] main[main] setup.go:83 'powerdns' module disabled in the config file
[ INFO ] main[main] setup.go:83 'pulsar' module disabled in the config file
[ INFO ] main[main] setup.go:83 'hdfs' module disabled in the config file
[ INFO ] main[main] setup.go:83 'unbound' module disabled in the config file
[ INFO ] main[main] setup.go:83 'logind' module disabled in the config file
[ INFO ] main[main] setup.go:83 'mysql' module disabled in the config file
[ INFO ] main[main] setup.go:83 'supervisord' module disabled in the config file
[ INFO ] main[main] setup.go:83 'nvme' module disabled in the config file
[ INFO ] main[main] setup.go:83 'portcheck' module disabled in the config file
[ INFO ] main[main] setup.go:83 'prometheus' module disabled in the config file
[ INFO ] main[main] setup.go:83 'dnsmasq_dhcp' module disabled in the config file
[ INFO ] main[main] setup.go:83 'dockerhub' module disabled in the config file
[ INFO ] main[main] setup.go:83 'elasticsearch' module disabled in the config file
[ INFO ] main[main] setup.go:83 'fluentd' module disabled in the config file
[ INFO ] main[main] setup.go:83 'isc_dhcpd' module disabled in the config file
[ INFO ] main[main] setup.go:83 'apache' module disabled in the config file
[ INFO ] main[main] setup.go:83 'geth' module disabled in the config file
[ INFO ] main[main] setup.go:83 'scaleio' module disabled in the config file
[ INFO ] main[main] setup.go:83 'phpdaemon' module disabled in the config file
[ INFO ] main[main] setup.go:83 'pika' module disabled in the config file
[ INFO ] main[main] setup.go:83 'solr' module disabled in the config file
[ INFO ] main[main] setup.go:83 'httpcheck' module disabled in the config file
[ INFO ] main[main] setup.go:83 'k8s_kubeproxy' module disabled in the config file
[ INFO ] main[main] setup.go:83 'ntpd' module disabled in the config file
[ INFO ] main[main] setup.go:79 'nvidia_smi' module disabled by default, should be explicitly enabled in the config
[ INFO ] main[main] setup.go:79 'openvpn' module disabled by default, should be explicitly enabled in the config
[ INFO ] main[main] setup.go:83 'squidlog' module disabled in the config file
[ INFO ] main[main] setup.go:83 'rabbitmq' module disabled in the config file
[ INFO ] main[main] setup.go:83 'springboot2' module disabled in the config file
[ INFO ] main[main] setup.go:83 'activemq' module disabled in the config file
[ INFO ] main[main] setup.go:83 'bind' module disabled in the config file
[ INFO ] main[main] setup.go:83 'energid' module disabled in the config file
[ INFO ] main[main] setup.go:83 'k8s_kubelet' module disabled in the config file
[ INFO ] main[main] setup.go:79 'k8s_state' module disabled by default, should be explicitly enabled in the config
[ INFO ] main[main] setup.go:88 enabled/registered modules: 1/79
[ INFO ] main[main] setup.go:93 building discovery config
[ INFO ] main[main] setup.go:123 looking for 'snmp.conf' in [/etc/netdata/go.d /usr/lib/netdata/conf.d/go.d]
[ INFO ] main[main] setup.go:139 found '/etc/netdata/go.d/snmp.conf
[ INFO ] main[main] setup.go:144 dummy/read/watch paths: 0/1/0
[ INFO ] discovery[manager] manager.go:92 registered discoverers: [file discovery: [file reader]]
[ INFO ] discovery[manager] manager.go:97 instance is started
[ INFO ] discovery[file manager] discovery.go:73 instance is started
[ INFO ] run[manager] run.go:32 instance is started
[ INFO ] build[manager] build.go:107 instance is started
[ INFO ] discovery[file reader] read.go:41 instance is started
[ INFO ] discovery[file reader] read.go:42 instance is stopped
[ DEBUG ] build[manager] build.go:154 received config group ('/etc/netdata/go.d/snmp.conf'): 1 jobs (added: 1, removed: 0)
[ DEBUG ] build[manager] build.go:303 building snmp[cps] job, config: map[__provider__:file reader __source__:/etc/netdata/go.d/snmp.conf autodetection_retry:0 charts:[map[dimensions:[map[algorithm:incremental divisor:1 multiplier:1 name:cabinet oid:1.3.6.1.4.1.3808.1.1.6.6.2.4.1.6.8]] id:outlet_status_load type:area units:amps] map[dimensions:[map[algorithm:incremental divisor:1 multiplier:1 name:cabinet oid:1.3.6.1.4.1.3808.1.1.6.6.2.4.1.7.8]] id:outlet_status_active_power type:area units:watts]] community:public hostname:172.16.10.240 max_request_size:150 module:snmp name:cps options:map[version:2] priority:70000 update_every:1]
[ INFO ] snmp[cps] snmp.go:117 hostname=172.16.10.240,port=161,snmp_version=2c,community=public
[ INFO ] snmp[cps] job.go:194 check success
[ INFO ] snmp[cps] job.go:214 started, data collection interval 1s
CHART 'netdata.execution_time_of_snmp_cps' '' 'Execution time' 'ms' 'go.d' 'netdata.go_plugin_execution_time' 'line' '145000' '1' '' 'go.d' 'snmp'
CLABEL '_collect_job' 'cps' '1'
CLABEL_COMMIT
DIMENSION 'time' '' 'absolute' '1' '1' ''
CHART 'snmp_cps.outlet_status_load' '' 'Untitled chart' 'amps' '' 'snmp.outlet_status_load' 'area' '70000' '1' '' 'go.d' 'snmp'
CLABEL_COMMIT
DIMENSION 'cabinet' 'cabinet' 'incremental' '1' '1' ''
SET 'cabinet' = 8
END
CHART 'snmp_cps.outlet_status_active_power' '' 'Untitled chart' 'watts' '' 'snmp.outlet_status_active_power' 'area' '70000' '1' '' 'go.d' 'snmp'
CLABEL_COMMIT
SET 'cabinet' = 50
END
BEGIN 'netdata.execution_time_of_snmp_cps'
SET 'time' = 1
END
[ DEBUG ] run[manager] run.go:43 tick 1
SET 'cabinet' = 8
END
SET 'cabinet' = 50
END
BEGIN 'netdata.execution_time_of_snmp_cps' 999555
SET 'time' = 1
END
[ DEBUG ] run[manager] run.go:43 tick 2
BEGIN 'snmp_cps.outlet_status_load' 1000290
SET 'cabinet' = 8
END
BEGIN 'snmp_cps.outlet_status_active_power' 1000290
SET 'cabinet' = 50
END
BEGIN 'netdata.execution_time_of_snmp_cps' 1000290
SET 'time' = 0
END
^C[ INFO ] main[main] agent.go:104 received interrupt signal (2). Terminating...
[ INFO ] run[manager] run.go:33 instance is stopped
[ INFO ] discovery[manager] manager.go:98 instance is stopped
[ INFO ] build[manager] build.go:108 instance is stopped
[ INFO ] discovery[file manager] discovery.go:74 instance is stopped
[ INFO ] snmp[cps] job.go:215 stopped
[ INFO ] main[main] agent.go:137 instance is stopped
netdata.conf
run as user = netdata
[db]
# default storage size - increase for longer data retention
dbengine page cache size MB = 32
dbengine multihost disk space MB = 256
[web]
#web files owner = root
#web files group = root
# Netdata is not designed to be exposed to potentially hostile
# networks. See https://github.com/netdata/netdata/issues/164
bind to = 10.106.249.194
[plugins]
timex = no
idlejitter = no
netdata monitoring = no
tc = no
diskspace = no
proc = no
cgroups = no
check for new plugins every = 60
slabinfo = no
ebpf = no
charts.d = no
go.d = yes
python.d = no
nfacct = no
ioping = no
perf = no
apps = no
statsd = no
cps.html
<!DOCTYPE html>
<html lang="en">
<head>
<title>Your dashboard</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
<meta name="viewport" content="width=device-width, initial-scale=1">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="black-translucent">
<!-- here we will add dashboard.js -->
<script type="text/javascript" src="http://10.106.249.194:19999/dashboard.js"></script>
</head>
<body>
<!-- here we will add charts -->
<div data-netdata="snmp_cps.outlet_status_load"></div>
<div data-netdata="snmp_cps.outlet_status_active_power"></div>
</body>
</html>
