Removed any go.d metering
Packaging:
Netdata Version ____________________________________________ : v1.43.0-343-nightly
Package Distro _____________________________________________ :
Configure Options __________________________________________ : '--build=x86_64-linux-gnu' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--disable-option-checking' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--libexecdir=${prefix}/lib/x86_64-linux-gnu' '--disable-maintainer-mode' '--prefix=/usr' '--sysconfdir=/etc' '--localstatedir=/var' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--with-user=netdata' '--with-math' '--with-zlib' '--with-webdir=/var/lib/netdata/www' '--disable-dependency-tracking' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -ffile-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -ffile-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security'
Default Directories:
Static Web Files ___________________________________________ : /var/lib/netdata/www
Operating System:
Kernel Version _____________________________________________ : 5.15.0-89-generic
Operating System ___________________________________________ : Ubuntu
Operating System ID ________________________________________ : ubuntu
Operating System ID Like ___________________________________ : debian
Operating System Version ___________________________________ : 22.04.3 LTS (Jammy Jellyfish)
Hardware:
CPU Cores __________________________________________________ : 1
CPU Frequency ______________________________________________ : 2400000000
CPU Architecture ___________________________________________ : 1447915520
RAM Bytes __________________________________________________ : 21474836480
Disk Capacity ______________________________________________ : x86_64
Virtualization Technology __________________________________ : microsoft
Container:
Features:
Database Engines:
dbengine ___________________________________________________ : YES
map ________________________________________________________ : YES
save _______________________________________________________ : YES
Connectivity Capabilities:
Libraries:
Judy (high-performance dynamic arrays and hashtables) ______ : YES (bundled)
dlib (robust machine learning toolkit) _____________________ : YES (bundled)
libm (mathematical functions) ______________________________ : YES
jemalloc ___________________________________________________ : NO
TCMalloc ___________________________________________________ : NO
Plugins:
Xen ________________________________________________________ : NO
Logs Management ____________________________________________ : YES
Exporters:
Debug/Developer Features:
Agent to stream any declared incoming streams and measure any defined and/or found metrics locally.
Tried to completely remove/purge any netdata information from the Ubuntu 22.04_3 host and re-install it via the kickstart script, alas to the same effect.
First of all, I was not clear when I wrote “disable go.d metering”. I meant not specify particular metrics, such as prometheus or snmp… i.e. leave it as-is by default, performing automatic endpoint recognition for metrics.
netdata-dbgsym package was not found using apt-get under Ubuntu 22. Tried netdata-core-dbgsym as well, to no avail.
If I executed your instructions correctly, the bt output is:
Core was generated by `/usr/sbin/netdata -D -P /var/run/netdata/netdata.pid'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x000055d739d5b37d in ?? ()
[Current thread is 1 (Thread 0x7ff6fce18640 (LWP 657769))]
(gdb) bt
#1 0x000055d739edcab1 in ?? ()
#2 0x000055d739f0708b in ?? ()
#3 0x000055d739d59b26 in ?? ()
#4 0x000055d739d5b06d in ?? ()
#5 0x000055d739f09870 in ?? ()
#6 0x000055d739ec93fc in ?? ()
#7 0x000055d739ed3795 in ?? ()
#8 0x000055d739ec40ca in ?? ()
#9 0x000055d739d9116f in ?? ()
#10 0x00007ff7189bdac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
#11 0x00007ff718a4fa40 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
$ dpkg -l | grep netdata
ii netdata 1.43.0-343-nightly amd64 real-time charts for system monitoring
ii netdata-ebpf-code-legacy 1.43.0-343-nightly amd64 Compiled eBPF legacy code for the Netdata eBPF plugin
ii netdata-plugin-apps 1.43.0-343-nightly amd64 The per-application metrics collection plugin for the Netdata Agent
ii netdata-plugin-chartsd 1.43.0-343-nightly all The charts.d metrics collection plugin for the Netdata Agent
ii netdata-plugin-debugfs 1.43.0-343-nightly amd64 The debugfs metrics collector for the Netdata Agent
ii netdata-plugin-ebpf 1.43.0-343-nightly amd64 The eBPF metrics collection plugin for the Netdata Agent
ii netdata-plugin-go 1.43.0-343-nightly amd64 The go.d metrics collection plugin for the Netdata Agent
ii netdata-plugin-logs-management 1.43.0-343-nightly amd64 The logs-management plugin for the Netdata Agent
ii netdata-plugin-nfacct 1.43.0-343-nightly amd64 The NFACCT metrics collection plugin for the Netdata Agent
ii netdata-plugin-perf 1.43.0-343-nightly amd64 The perf metrics collector for the Netdata Agent
ii netdata-plugin-pythond 1.43.0-343-nightly all The python.d metrics collection plugin for the Netdata Agent
ii netdata-plugin-slabinfo 1.43.0-343-nightly amd64 The slabinfo metrics collector for the Netdata Agent
ii netdata-plugin-systemd-journal 1.43.0-343-nightly amd64 The systemd-journal collector for the Netdata Agent
ii netdata-repo-edge 2-1 all Configuration for the official Netdata Edge package repository.
$ apt-cache search netdata
netdata-apache2 - real-time performance monitoring (apache integration)
netdata-core - real-time performance monitoring (core)
netdata-plugins-bash - real-time performance monitoring (bash plugins)
netdata-plugins-nodejs - real-time performance monitoring (nodejs plugins)
netdata-plugins-python - real-time performance monitoring (python plugins)
netdata-web - real-time performance monitoring (web)
netdata - real-time charts for system monitoring
netdata-dbgsym - debug symbols for netdata
netdata-ebpf-code-legacy - Compiled eBPF legacy code for the Netdata eBPF plugin
netdata-plugin-apps - The per-application metrics collection plugin for the Netdata Agent
netdata-plugin-apps-dbgsym - debug symbols for netdata-plugin-apps
netdata-plugin-chartsd - The charts.d metrics collection plugin for the Netdata Agent
netdata-plugin-cups - The CUPS metrics collection plugin for the Netdata Agent
netdata-plugin-cups-dbgsym - debug symbols for netdata-plugin-cups
netdata-plugin-debugfs - The debugfs metrics collector for the Netdata Agent
netdata-plugin-debugfs-dbgsym - debug symbols for netdata-plugin-debugfs
netdata-plugin-ebpf - The eBPF metrics collection plugin for the Netdata Agent
netdata-plugin-ebpf-dbgsym - debug symbols for netdata-plugin-ebpf
netdata-plugin-freeipmi - The FreeIPMI metrics collection plugin for the Netdata Agent
netdata-plugin-freeipmi-dbgsym - debug symbols for netdata-plugin-freeipmi
netdata-plugin-go - The go.d metrics collection plugin for the Netdata Agent
netdata-plugin-logs-management - The logs-management plugin for the Netdata Agent
netdata-plugin-logs-management-dbgsym - debug symbols for netdata-plugin-logs-management
netdata-plugin-nfacct - The NFACCT metrics collection plugin for the Netdata Agent
netdata-plugin-nfacct-dbgsym - debug symbols for netdata-plugin-nfacct
netdata-plugin-perf - The perf metrics collector for the Netdata Agent
netdata-plugin-perf-dbgsym - debug symbols for netdata-plugin-perf
netdata-plugin-pythond - The python.d metrics collection plugin for the Netdata Agent
netdata-plugin-slabinfo - The slabinfo metrics collector for the Netdata Agent
netdata-plugin-slabinfo-dbgsym - debug symbols for netdata-plugin-slabinfo
netdata-plugin-systemd-journal - The systemd-journal collector for the Netdata Agent
netdata-plugin-systemd-journal-dbgsym - debug symbols for netdata-plugin-systemd-journal
netdata-repo - Configuration for the official Netdata Stable package repository.
netdata-repo-edge - Configuration for the official Netdata Edge package repository
ii netdata 1.44.0-2-nightly amd64 real-time charts for system monitoring
ii netdata-ebpf-code-legacy 1.44.0-2-nightly amd64 Compiled eBPF legacy code for the Netdata eBPF plugin
ii netdata-plugin-apps 1.44.0-2-nightly amd64 The per-application metrics collection plugin for the Netdata Agent
ii netdata-plugin-chartsd 1.44.0-2-nightly all The charts.d metrics collection plugin for the Netdata Agent
ii netdata-plugin-debugfs 1.44.0-2-nightly amd64 The debugfs metrics collector for the Netdata Agent
ii netdata-plugin-ebpf 1.44.0-2-nightly amd64 The eBPF metrics collection plugin for the Netdata Agent
ii netdata-plugin-go 1.44.0-2-nightly amd64 The go.d metrics collection plugin for the Netdata Agent
ii netdata-plugin-logs-management 1.44.0-2-nightly amd64 The logs-management plugin for the Netdata Agent
ii netdata-plugin-nfacct 1.44.0-2-nightly amd64 The NFACCT metrics collection plugin for the Netdata Agent
ii netdata-plugin-perf 1.44.0-2-nightly amd64 The perf metrics collector for the Netdata Agent
ii netdata-plugin-pythond 1.44.0-2-nightly all The python.d metrics collection plugin for the Netdata Agent
ii netdata-plugin-slabinfo 1.44.0-2-nightly amd64 The slabinfo metrics collector for the Netdata Agent
ii netdata-plugin-systemd-journal 1.44.0-2-nightly amd64 The systemd-journal collector for the Netdata Agent
ii netdata-repo-edge 2-2 all Configuration for the official Netdata Edge package repository.
and
netdata-repo-edge - Configuration for the official Netdata Edge package repository.
