Environment
Ubuntu 20.04.3 5.4.0-88
My cloud server provider gave me a cdrom driver called sr0 in my server, and it shows up in netdata which I think unnecessary. How can I do to hide it?
You can disable charts in netdata.conf
[disk.sr0]
enabled = yes
Do the same for every chart disk_*.sr0
as well.
Another option is to exclude the disk using exclude disks
configuration option. It can be found under [plugin:proc:/proc/diskstats]
section in the netdata.conf
file.
I added these lines to netdata.conf
and they has been hidden in specify node tab, but they still show up in global node
tab, even after I cleanup all the data of the web page included IndexedDB, dit I do wrong?
[plugin:proc:/proc/diskstats:config-2]
enable = no
[disk.sr0]
enable = no
[disk_ext.sr0]
enable = no
[disk_ops.sr0]
enable = no
[disk_ext_ops.sr0]
enable = no
[disk_backlog.sr0]
enable = no
[disk_busy.sr0]
enable = no
[disk_util.sr0]
enable = no
[disk_iotime.sr0]
enable = no
[disk_ext_iotime.sr0]
enable = no
[disk_await.sr0]
enable = no
[disk_ext_await.sr0]
enable = no
[disk_avgsz.sr0]
enable = no
[disk_ext_avgsz.sr0]
enable = no
[disk_svctm.sr0]
enable = no
