https://my-netdata.io/kickstart-static64.sh is reporting 403 since today. I’ve checked the steps detailed here but no luck
Can someone please check if this is working externall ?
curl -Ssk https://my-netdata.io/kickstart-static64.sh Access to file is not permitted: /usr/share/netdata/web/kickstart-static64.sh
Hi Gaurav!
Welcome to the Netdata community! Sorry you were experiencing trouble with downloading and running the script. Our SRE team just deployed a fix on the permissions for this script and our other kickstart.sh script. At this point it should have propagated through CloudFlare and you should be able to download the script as expected.
Definitely give us an update if you have any other issues.
Thank you Joel. The processes worked fine !
