Im installing centos 6.10
GUI not showing few packages not found
please give me solution
few package name : autogen not installing for centos 6.10
Hello @Ajay-Dharvasthu ,
Few days ago I had to create a VM with CentOS 6 and I used the following steps before to compile Netdata:
1 - I enabled epel repository.
2 - I also enabled OKAY repository.
3 - I ran the following command that is described in our documentation:
# yum install autoconf automake curl gcc git libmnl-devel libuuid-devel openssl-devel libuv-devel lz4-devel Judy-devel elfutils-libelf-devel make nc pkgconfig python zlib-devel cmake
4 - Finally I installed Netdata:
./netdata-installer.sh --dont-wait
Netdata also has a script that helps to install what is necessary, but I normally do not use it, if you prerefer you can run:
# ./packaging/installer/install-required-packages.sh
Best regards!
