I’m experiencing an issue while trying to install Netdata using the kickstart script on Ubuntu 24.04 (Noble). The installation fails due to unmet dependencies.
Command used:wget -O /tmp/netdata-kickstart.sh https://get.netdata.cloud/kickstart.sh && sh /tmp/netdata-kickstart.sh
Error details: The system reports a version mismatch between netdata and its plugins:
netdata-plugin-chartsd depends on netdata (= 2.8.0-172-nightly) but 2.8.0-167-nightly is to be installed.
netdata-plugin-pythond depends on netdata (= 2.8.0-172-nightly) but 2.8.0-167-nightly is to be installed.
Suggested template:
The version mismatch occurs because the nightly build system is publishing packages with inconsistent version numbers. The plugin packages (netdata-plugin-chartsd, netdata-plugin-pythond) are being built with a newer version (172) than the core netdata package (167), causing APT dependency resolution to fail.
We advise you to install using the stable release channel instead of nightly:
wget -O /tmp/netdata-kickstart.sh ``https://get.netdata.cloud/kickstart.sh sh /tmp/netdata-kickstart.sh --stable-channel
