Heya, I am trying to add a netdata agent with docker. Here is my Docker compose
version: '3'
services:
netdata:
image: netdata/netdata:stable
container_name: netdata
ports:
- 19999:19999
restart: unless-stopped
cap_add:
- SYS_PTRACE
security_opt:
- apparmor:unconfined
volumes:
- /home/ritzz/server/netdata/etc:/etc/netdata
- /home/ritzz/server/netdata/lib:/var/lib/netdata
- /home/ritzz/server/netdata/cache:/var/cache/netdata
- /home/ritzz/server/netdata/passwd:/host/etc/passwd
- /home/ritzz/server/netdata/group:/host/etc/group
- /home/ritzz/server/netdata/proc:/host/proc
- /home/ritzz/server/netdata/sys:/host/sys
- /home/ritzz/server/netdata/os-release:/host/etc/os-release
environment:
- NETDATA_CLAIM_TOKEN=EDrkQaLMgy1eCqBPGUNG1-hNDeNsQc2nm3ROZwnvAGuOpZb--lWTS7Jgc9IfV2UrltdM3_FRZbkAZF8CB92UIqkbAz72rRoeVCP1QGDu0qX1XOYuZ47FXHgmAwtL2YwsgGOMfYY
- NETDATA_CLAIM_URL=https://app.netdata.cloud
- NETDATA_CLAIM_ROOMS=
- PUID=0
- PGID=0
- TZ=Asia/Calcutta
and here’s the log:
# : Invalid argument
2023-05-02 05:30:47: netdata FATAL : netdata : Failed to initialize SQLite
2023-05-02 05:30:47: netdata INFO : MAIN : /usr/libexec/netdata/plugins.d/anonymous-statistics.sh 'FATAL' 'netdata:netdata' '0942@database/r:rrd_init /22'
2023-05-02 05:30:48: netdata ERROR : MAIN : Execution of anonymous statistics script returned http code 400.
2023-05-02 05:30:48: netdata INFO : MAIN : NETDATA SHUTDOWN: initializing shutdown with code 1...
2023-05-02 05:30:48: netdata INFO : MAIN : /usr/libexec/netdata/plugins.d/anonymous-statistics.sh 'EXIT' 'ERROR' '-'
2023-05-02 05:30:49: netdata ERROR : MAIN : Execution of anonymous statistics script returned http code 400.
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: next: create shutdown file
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: in 0 ms, create shutdown file - next: disable maintenance, new queries, new web requests, new streaming connections and aclk
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: in 0 ms, disable maintenance, new queries, new web requests, new streaming connections and aclk - next: stop replication, exporters, ML training, health and web servers threads
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: in 0 ms, stop replication, exporters, ML training, health and web servers threads - next: stop collectors and streaming threads
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: in 0 ms, stop collectors and streaming threads - next: stop ML prediction and context threads
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: in 0 ms, stop ML prediction and context threads - next: stop maintenance thread
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: in 0 ms, stop maintenance thread - next: clean rrdhost database
2023-05-02 05:30:49: netdata INFO : MAIN : RRD: cleaning up database [0 hosts(s)]...
2023-05-02 05:30:49: netdata INFO : MAIN : NETDATA SHUTDOWN: in 0 ms, clean rrdhost database - next: prepare metasync shutdown
2023-05-02 05:30:49: netdata INFO : MAIN : METADATA: Sending a scan host command
Creating docker group 0
addgroup: gid '0' in use
Could not add group docker with ID 0, its already there probably
Assign netdata user to docker group 0
2023-05-02 05:30:55: netdata ERROR : MAIN : Ignoring host prefix '/host': path '/host/proc' is not a virtual file system (errno 22, Invalid argument)
2023-05-02 05:30:55: netdata INFO : MAIN : TIMEZONE: using TZ variable 'Asia/Calcutta'
2023-05-02 05:30:55: netdata INFO : MAIN : TIMEZONE: fixed as 'Asia/Calcutta'
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: next: initialize ML
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize ML - next: initialize signals
2023-05-02 05:30:55: netdata INFO : MAIN : SIGNAL: Enabling reaper
2023-05-02 05:30:55: netdata INFO : MAIN : process tracking enabled.
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize signals - next: initialize static threads
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize static threads - next: initialize web server
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize web server - next: set resource limits
2023-05-02 05:30:55: netdata INFO : MAIN : resources control: allowed file descriptors: soft = 1048576, max = 1048576
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, set resource limits - next: become daemon
2023-05-02 05:30:55: netdata INFO : MAIN : Out-Of-Memory (OOM) score is already set to the wanted value 0
2023-05-02 05:30:55: netdata ERROR : MAIN : Cannot adjust netdata scheduling policy to batch (3), with priority 0. Falling back to nice. (errno 38, Function not implemented)
2023-05-02 05:30:55: netdata ERROR : MAIN : Cannot get my current process scheduling policy. (errno 38, Function not implemented)
2023-05-02 05:30:55: netdata INFO : MAIN : netdata started on pid 1.
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, become daemon - next: initialize threads after fork
2023-05-02 05:30:55: netdata INFO : MAIN : Set threads stack size to 131072 bytes
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize threads after fork - next: initialize registry
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize registry - next: fork the spawn server
2023-05-02 05:30:55: netdata INFO : MAIN : Initializing spawn client.
2023-05-02 05:30:55: netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, fork the spawn server - next: collecting system info
2023-05-02 05:30:55: netdata INFO : MAIN : Executing /usr/libexec/netdata/plugins.d/system-info.sh
Spawn server is up.
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_CONTAINER_OS_NAME=Alpine Linux
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_CONTAINER_OS_ID=alpine
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_CONTAINER_OS_ID_LIKE=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_CONTAINER_OS_VERSION=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_CONTAINER_OS_VERSION_ID=3.16.4
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_CONTAINER_OS_DETECTION=/etc/os-release
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_CONTAINER_IS_OFFICIAL_IMAGE=true
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_HOST_OS_NAME=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_HOST_OS_ID=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_HOST_OS_ID_LIKE=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_HOST_OS_VERSION=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_HOST_OS_VERSION_ID=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_HOST_OS_DETECTION=/host/etc/os-release
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_HOST_IS_K8S_NODE=false
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_KERNEL_NAME=Linux
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_KERNEL_VERSION=5.19.0-41-generic
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_ARCHITECTURE=x86_64
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_VIRTUALIZATION=none
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_VIRT_DETECTION=none
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_CONTAINER=docker
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_CONTAINER_DETECTION=dockerenv
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_LOGICAL_CPU_COUNT=4
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_VENDOR=GenuineIntel
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_MODEL=Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_FREQ=3400000000
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_CPU_DETECTION=lscpu
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_TOTAL_RAM=12432912384
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_RAM_DETECTION=procfs
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_TOTAL_DISK_SIZE=10120865472512
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_SYSTEM_DISK_DETECTION=sysfs
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_TYPE=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_INSTANCE_TYPE=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_INSTANCE_REGION=unknown
2023-05-02 05:30:56: netdata INFO : MAIN : NETDATA STARTUP: in 56 ms, collecting system info - next: initialize RRD structures
2023-05-02 05:30:56: netdata ERROR : MAIN : Failed to initialize database at /var/cache/netdata/netdata-meta.db, due to "unable to open database file"
It fails to create an SQLite from what I see. How do I fix this?
