Environment
QNAP QTS with docker
I have always installed netdata in my qnap with a docker and it worked fine for me. But from a certain version it seems that the netdata container cannot be started.
I use this for installation:
docker run -d --name=netdata
-p 19999:19999
-v /share/mydirectory/netdata/netdataconfig/netdata:/etc/netdata:ro
-v netdatalib:/var/lib/netdata
-v netdatacache:/var/cache/netdata
-v /etc/passwd:/host/etc/passwd:ro
-v /etc/group:/host/etc/group:ro
-v /proc:/host/proc:ro
-v /sys:/host/sys:ro
-v /etc/os-release:/host/etc/os-release:ro
–restart unless-stopped
–cap-add SYS_PTRACE
–security-opt apparmor=unconfined
netdata/netdata
It seems like a permission problem perhaps, but I don’t know what I can do to solve it.
I have seen that a user with synology had problems and it solved it with the installation of netdata with composer something like this:
environment:
- DOCKER_USR = nameusrofuser
But I install directly in the terminal without compose and I don’t know how I can put my environment variables at installation time.
Could you help me get the netdata container to start correctly?
Thanks!
LOG NETDATA:
2021-09-17 18:12:37: netdata INFO : MAIN : EXIT: netdata prepares to exit with code 1...
2021-09-17 18:12:37: netdata INFO : MAIN : EXIT: cleaning up the database...
2021-09-17 18:12:37: netdata INFO : MAIN : Cleaning up database [0 hosts(s)]...
2021-09-17 18:12:37: netdata INFO : MAIN : EXIT: all done - netdata is now exiting - bye bye...
ls: /var/run/balena.sock: No such file or directory
ls: /var/run/docker.sock: No such file or directory
2021-09-17 18:13:39: netdata INFO : MAIN : CONFIG: cannot load user config '/etc/netdata/netdata.conf'. Will try the stock version.
2021-09-17 18:13:39: netdata INFO : MAIN : CONFIG: cannot load stock config '/usr/lib/netdata/conf.d/netdata.conf'. Running with internal defaults.
2021-09-17 18:13:39: netdata INFO : MAIN : CONFIG: cannot load cloud config '/var/lib/netdata/cloud.d/cloud.conf'. Running with internal defaults.
2021-09-17 18:13:39: netdata INFO : MAIN : Using host prefix directory '/host'
2021-09-17 18:13:39: netdata INFO : MAIN : TIMEZONE: using strftime(): 'UTC'
2021-09-17 18:13:39: netdata INFO : MAIN : TIMEZONE: fixed as 'UTC'
2021-09-17 18:13:39: netdata INFO : MAIN : SIGNAL: Enabling reaper
2021-09-17 18:13:39: netdata INFO : MAIN : process tracking enabled.
2021-09-17 18:13:39: netdata INFO : MAIN : resources control: allowed file descriptors: soft = 65535, max = 65535
2021-09-17 18:13:39: netdata INFO : MAIN : Adjusted my Out-Of-Memory (OOM) score from 0 to 1000.
2021-09-17 18:13:39: netdata ERROR : MAIN : Cannot adjust netdata scheduling policy to idle (5), with priority 0. Falling back to nice. (errno 38, Function not implemented)
2021-09-17 18:13:39: netdata ERROR : MAIN : Cannot get my current process scheduling policy. (errno 38, Function not implemented)
2021-09-17 18:13:39: netdata INFO : MAIN : netdata started on pid 1.
2021-09-17 18:13:39: netdata FATAL : MAIN : Cannot create directory '/var/lib/netdata/registry'. # : Invalid argument
