Linux sensors Charts: Not all metrics charts being shown
My netdata running on v2.1.1 on Linux Machine doesn’t show all the metrics supported under Linux sensors collector. It only shows voltage and current.
  1. Linux Sensors | Learn Netdata
  2. Linux Sensors Monitoring | Netdata
Netdata: v2.1.1
Type:lxc
O/S version:Ubuntu, 22.04.4 LTS (Jammy Jellyfish)
Architecture:aarch64
Kernel:Linux, 5.15.136-tegra
I expect all these sensors metrics charts to be shown on the dashboard: Temperature, Fan, Power, Energy, Humidity, Intrusion
Hi, @meghnamscs. Not all systems will expose all sensor types. The sensors available to this collector are limited to those provided by your system’s hardware and enabled through the appropriate kernel drivers.
I will update the description.
Do you expect parity between the old lm-sensors plugin and new Go collector? Because those sensors used to get picked up properly by lm-sensors.
The go collector collects all sensors exposed by your system. Anyway, v.2.2.0 contains c implementation of the sensors collector.
I tested v2.2.0 on my machine, it’s the same: I only see Voltage and Current sensors.
