I upgraded to 1.44 and I’m getting a lot of errors that say 'maximum number of cgroups reached (1000). Is there a way to raise the limit?
I found it
[plugin:cgroups]
# netdata server resources = yes
# check for new plugin every = 10
# enable cpuacct stat = on demand
# enable cpuacct usage = on demand
# enable memory = on demand
# enable blkio = on demand
# path to /sys/fs/cgroup/cpuacct = /sys/fs/cgroup/cpuacct
# path to /sys/fs/cgroup/blkio = /sys/fs/cgroup/blkio
# path to /sys/fs/cgroup/memory = /sys/fs/cgroup/memory
# max cgroups to allow = 50
Hi, @data-smith. Fixed in latest netdata/pull/16730
For the stable version: change the logs severity level to “warning” (it will remove all info lines including that one).
In netdata.conf
[logs]
level = warning
