hello
i use to monitor my kubernetes cluster , it work perfectly
but i dont see my deployment, all of my deployment have volumes with persistant data , but i cannot find it in netdata ?
Is there something i need to do ?
thanks
hello
thanks
I guess you have Netdata installed inside the k8s cluster, correct?
If so, we haven’t found a solution how to collect mount points metrics that are not mounted to the Netdata container.
See related topic.
Hello
Thanks for the response…
Yes I installed netdata in the cluster.
Netdata is very cool
But my aim is to monitor deployement , do you know a solution for that ?
Thanks
