I am trying to monitor 3 separate PostgreSQL instances with Netdata’s go.d.plugin
on a Raspberry Pi 5.
Each instance has a separate job defined in /etc/netdata/go.d/postgres-*.conf
with different name:
and dsn:
values.
However, when I open the Netdata UI, only a single exporter appears, and all metrics from 3 instances are merged into one screen.
Expected behavior:
Each job (dev, local, test) should appear as a separate PostgreSQL exporter with its own charts.
- I followed the official Netdata PostgreSQL integration guide[image]
- Created 3 separate config files:
/etc/netdata/go.d/postgres-local.conf
/etc/netdata/go.d/postgres-dev.conf
/etc/netdata/go.d/postgres-test.conf
- Each contains:
yaml
jobs:
- name: dev
enabled: true
dsn: postgresql://netdata:PASSWORD@<host>:5432/postgres
(Each job uses different DSN and name)
- Ensured ownership and permissions:
bash
chown netdata:netdata /etc/netdata/go.d/postgres-*.conf
chmod 644 /etc/netdata/go.d/postgres-*.conf
go.d.conf
includes:
yaml
enabled: yes
default_run: yes
config_dirs:
- /etc/netdata/go.d
modules.conf
yaml
enabled: yes
postgres: yes
- Confirmed config is being loaded with:
bash
sudo -u netdata /usr/libexec/netdata/plugins.d/go.d.plugin -d -m postgres
Only one job appears (either local
or dev
, not all 3).
- Device: Raspberry Pi 5
- OS: Ubuntu 24.04
- Netdata version:
v2.3.2
- Browser: Chrome 123+
- Accessing directly via local Netdata Agent UI (not Cloud)
bash
netdata -v
netdata -W buildinfo
root@raspberrypi5:/etc/netdata/go.d# netdata -v
netdata v2.3.2
time=2025-04-14T21:27:34.841+03:00 comm=netdata source=daemon level=notice errno="2, No such file or directory" tid=393194 msg="CONFIG: cannot load user config '/etc/netdata/stream.conf'. Will try stock config."
time=2025-04-14T21:27:34.841+03:00 comm=netdata source=daemon level=error errno="22, Invalid argument" tid=393194 msg="madvise(MADV_MERGEABLE) of size 16384, failed."
Packaging:
Netdata Version ____________________________________________ : v2.3.2
Package Architecture _______________________________________ : aarch64
Package Distro _____________________________________________ : ubuntu 24.04
Configure Options __________________________________________ : cmake -DCMAKE_BUILD_TYPE=RelWithDebInfo -DCMAKE_C_STANDARD=11 -DCMAKE_CXX_STANDARD=14 -DBUILD_SHARED_LIBS= -DCMAKE_C_FLAGS=' -fexceptions -fexceptions -fno-omit-frame-pointer -funwind-tables -fasynchronous-unwind-tables' -DCMAKE_CXX_FLAGS=' -fexceptions -fexceptions -fno-omit-frame-pointer -funwind-tables -fasynchronous-unwind-tables' -DCMAKE_COMPILE_DEFINITIONS='_GNU_SOURCE' -DCMAKE_EXE_LINKER_FLAGS=' -fexceptions -fexceptions -rdynamic' -DCMAKE_SHARED_LINKER_FLAGS=''
Default Directories:
Operating System:
Kernel Version _____________________________________________ : 6.8.0-1020-raspi
Operating System ___________________________________________ : Ubuntu
Operating System ID ________________________________________ : ubuntu
Operating System ID Like ___________________________________ : debian
Operating System Version ___________________________________ : 24.04.2 LTS (Noble Numbat)
Hardware:
CPU Cores __________________________________________________ : 4
CPU Frequency ______________________________________________ : 2400000000
RAM Bytes __________________________________________________ : 8323276800
Disk Capacity ______________________________________________ : 128177930240
CPU Architecture ___________________________________________ : aarch64
Virtualization Technology __________________________________ : none
Container:
Features:
Memory Allocator ___________________________________________ : system
Database Engines:
dbengine (compression) _____________________________________ : YES (zstd lz4)
Connectivity Capabilities:
h2o (web server) ___________________________________________ : NO
Libraries:
libmnl (library for working with netfilter) ________________ : YES
stacktraces (library for getting stack traces) _____________ : libbacktrace (mmap, threads, data)
Plugins:
windows (monitor Windows systems) __________________________ : NO
ebpf (monitor system calls) ________________________________ : NO
network-viewer (monitor TCP/UDP IPv4/6 sockets) ____________ : YES
systemd-journal (monitor journal logs) _____________________ : YES
windows-events (monitor Windows events) ____________________ : NO
Xen ________________________________________________________ : YES
Exporters:
Debug/Developer Features:
Runtime Information:
Profile ____________________________________________________ : standalone
Stream Parent (accept data from Children) __________________ : NO
Stream Child (send data to a Parent) _______________________ : NO
Total System Memory ________________________________________ : 8323276800
Available System Memory ____________________________________ : 7033450496
I expected each PostgreSQL job defined with a unique name to appear as a separate exporter, or at least have a clean separation of charts in the UI.
Instead, all 3 instances appear to be merged into a single PostgreSQL section, making it impossible to monitor them independently.
Please confirm whether:
- This is expected behavior?
- There is any config to force each job to be separated visually?
- Or a known limitation of the current go.d.postgres collector?
