On the local netdata agent dashboard in the alerts tab I used to be able to see all raised alerts but also all clear alerts per node. Today I recognized, that only raised alerts are shown (see screenshot below). I would expect to not only see the raised alerts but also the clear alerts. Is this feature perhaps now only available in netdata cloud or is this a misconfiguration / bug?
Steps to reproduce
- Open the dashboard of the netdata agent.
- Click on the alerts tab.
I can reproduce the issue both on Google Chrome and Firefox. I did not check with other browsers.
Installation method
kickstart.sh
System info
Linux xyz 6.8.0-44-generic #44-Ubuntu SMP PREEMPT_DYNAMIC Tue Aug 13 13:35:26 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
/etc/lsb-release:DISTRIB_ID=Ubuntu
/etc/lsb-release:DISTRIB_RELEASE=24.04
/etc/lsb-release:DISTRIB_CODENAME=noble
/etc/lsb-release:DISTRIB_DESCRIPTION=“Ubuntu 24.04.1 LTS”
/etc/os-release:PRETTY_NAME=“Ubuntu 24.04.1 LTS”
/etc/os-release:NAME=“Ubuntu”
/etc/os-release:VERSION_ID=“24.04”
/etc/os-release:VERSION=“24.04.1 LTS (Noble Numbat)”
/etc/os-release:VERSION_CODENAME=noble
/etc/os-release:ID=ubuntu
/etc/os-release:ID_LIKE=debian
/etc/os-release:UBUNTU_CODENAME=noble
/etc/os-release:LOGO=ubuntu-logo
Netdata build info
Packaging:
Netdata Version ____________________________________________ : v1.47.1
Package Distro _____________________________________________ : ubuntu 24.04
Configure Options __________________________________________ : dummy-configure-command
Default Directories:
Operating System:
Kernel Version _____________________________________________ : 6.8.0-44-generic
Operating System ___________________________________________ : Ubuntu
Operating System ID ________________________________________ : ubuntu
Operating System ID Like ___________________________________ : debian
Operating System Version ___________________________________ : 24.04.1 LTS (Noble Numbat)
Hardware:
CPU Cores __________________________________________________ : 8
CPU Frequency ______________________________________________ : 2294000000
RAM Bytes __________________________________________________ : 32862339072
Disk Capacity ______________________________________________ : 245761048576
CPU Architecture ___________________________________________ : x86_64
Virtualization Technology __________________________________ : kvm
Container:
Features:
Database Engines:
dbengine (compression) _____________________________________ : YES (zstd lz4)
Connectivity Capabilities:
Libraries:
libmnl (library for working with netfilter) ________________ : YES
Plugins:
Xen ________________________________________________________ : YES
Exporters:
Debug/Developer Features:
