Good afternoon. I am new to netdata, so I may still be confused about the terminology.
on my production server, the netdata agent is already running and collecting data, visualisation is working, including correct display of mysql plugins, etc.
But now I need to have a chart created for freeradius.
I used the documentation for installing the plugin - FreeRADIUS | Netdata - and it doesn’t work (:
Here is what I have:
cat /etc/netdata/go.d.conf
modules:
example: no
prometheus: no
k8s_state: no
k8s_kubeproxy: no
k8s_kubelet: no
nginx: yes
mysql: yes
postgres: yes
supervisord: yes
freeradius: yes
phpfpm: yes
redis: yes
openvpn: yes
Status work in freeradius:
server status {
listen {
# ONLY Status-Server is allowed to this port.
# ALL other packets are ignored.
type = status
ipaddr = 127.0.0.1
port = 18121
client admin {
ipaddr = 127.0.0.1
secret = adminsecret
/usr/lib/netdata/conf.d]
[ INFO ] main[main] setup.go:188 found '/usr/lib/netdata/conf.d/vnodes' (0 vhosts)
[ INFO ] discovery[manager] manager.go:97 instance is started
[ INFO ] run[manager] run.go:32 instance is started
[ INFO ] build[manager] build.go:117 instance is started
[ INFO ] discovery[file manager] discovery.go:73 instance is started
[ INFO ] discovery[file reader] read.go:41 instance is started
[ INFO ] discovery[file reader] read.go:42 instance is stopped
[ DEBUG ] build[manager] build.go:164 received config group ('/etc/netdata/go.d/freeradius.conf'): 1 jobs (added: 1, removed: 0)
[ DEBUG ] build[manager] build.go:313 building freeradius[local] job, config: map[__provider__:file reader __source__:/etc/netdata/go.d/freeradius.conf address:127.0.0.1 autodetection_retry:0 module:freeradius name:local port:18121 priority:70000 secret:adminsecret update_every:1]
[ INFO ] freeradius[local] job.go:208 check success
[ INFO ] freeradius[local] job.go:228 started, data collection interval 1s
CHART 'netdata.execution_time_of_freeradius_local' '' 'Execution time' 'ms' 'go.d' 'netdata.go_plugin_execution_time' 'line' '145000' '1' '' 'go.d' 'freeradius'
CLABEL '_collect_job' 'local' '1'
CLABEL_COMMIT
DIMENSION 'time' '' 'absolute' '1' '1' ''
CHART 'freeradius_local.authentication' '' 'Authentication' 'packets/s' 'authentication' 'freeradius.authentication' 'line' '70000' '1' '' 'go.d' 'freeradius'
CLABEL_COMMIT
DIMENSION 'requests' 'requests' 'incremental' '1' '1' ''
DIMENSION 'responses' 'responses' 'incremental' '1' '1' ''
BEGIN 'freeradius_local.authentication'
SET 'requests' = 8054
SET 'responses' = 7435
END
