Our agent just restarted and we dont know the reason.
/opt/netdata/usr/bin/netdata -v
netdata v1.42.0-97-ge9989c519
error.log
2023-08-31 00:09:08: netdata INFO : UV_WORKER[16] : METADATA: Freeing 3 database pages
2023-08-31 00:09:34: netdata INFO : MAIN : SIGNAL: Received SIGTERM. Cleaning up to exit...
Environment
/opt/netdata//etc/netdata/.environment
# Created by installer
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
CFLAGS="-ffunction-sections -fdata-sections -static -O2 -funroll-loops -I/openssl-static/include -I/libnetfilter-acct-static/include/libnetfilter_acct -I/usr/include/libmnl -pipe"
LDFLAGS="-Wl,--gc-sections -static -L/openssl-static/lib64 -L/libnetfilter-acct-static/lib -lnetfilter_acct -L/usr/lib -lmnl"
MAKEOPTS="-j2"
NETDATA_TMPDIR="/tmp"
NETDATA_PREFIX="/opt/netdata"
NETDATA_CONFIGURE_OPTIONS=" --enable-cloud --without-bundled-protobuf --disable-dependency-tracking --enable-lto"
NETDATA_ADDED_TO_GROUPS=" docker nginx varnish haproxy adm nsd proxy squid ceph nobody"
INSTALL_UID="0"
NETDATA_GROUP="netdata"
REINSTALL_OPTIONS=" --disable-telemetry"
RELEASE_CHANNEL="nightly"
IS_NETDATA_STATIC_BINARY="yes"
NETDATA_LIB_DIR="/opt/netdata/var/lib/netdata"
journalctl -u netdata.service
Aug 29 07:16:31 blue [1143]: NFACCT reached my lifetime expectancy. Exiting to restart.
Aug 29 07:16:32 blue [12498]: Zswap is disabled
Aug 29 07:16:32 blue [12498]: Failed to find powercap zones.
Aug 30 02:03:23 blue [1116]: Cannot process /proc/6162/limits (command 'sed')
Aug 30 07:16:33 blue [13338]: Zswap is disabled
Aug 30 07:16:33 blue [13338]: Failed to find powercap zones.
Aug 30 07:16:33 blue [12505]: NFACCT reached my lifetime expectancy. Exiting to restart.
Aug 31 00:09:34 blue systemd[1]: Stopping Real time performance monitoring...
Aug 31 00:09:34 blue [1133]: thread with task id 1151 finished
Aug 31 00:09:34 blue [1133]: thread with task id 1158 finished
Aug 31 00:09:34 blue [1133]: thread with task id 1154 finished
Aug 31 00:09:35 blue [1133]: thread with task id 1157 finished
Aug 31 00:09:35 blue [1133]: thread with task id 1152 finished
Aug 31 00:09:35 blue [9881]: PROCFILE: Cannot open file '/opt/netdata/etc/netdata/apps_groups.conf'
Aug 31 00:09:35 blue [9881]: Cannot read process groups configuration file '/opt/netdata/etc/netdata/apps_groups.conf'. Will try '/opt>
Aug 31 00:09:35 blue [9881]: Loaded config file '/opt/netdata/usr/lib/netdata/conf.d/apps_groups.conf'
Aug 31 00:09:35 blue [1133]: eBPF cannot unload all threads on time, but it will go away
Aug 31 00:09:35 blue [9881]: started on pid 9881
Aug 31 00:09:35 blue [9881]: set name of thread 9885 to APPS_READER
Aug 31 00:09:35 blue [1133]: thread with task id 1160 finished
Aug 31 00:09:36 blue [9881]: Using now_boottime_usec() for uptime (dt is 8 ms)
Aug 31 00:09:36 blue [9882]: Zswap is disabled
Aug 31 00:09:36 blue [9882]: Failed to find powercap zones.
Aug 31 00:09:36 blue [1133]: thread with task id 1153 finished
Aug 31 00:09:36 blue [1133]: thread with task id 1156 finished
Aug 31 00:09:36 blue [1133]: eBPF cannot unload all threads on time, but it will go away
Aug 31 00:12:04 blue systemd[1]: netdata.service: State 'stop-sigterm' timed out. Killing.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 942 (netdata) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 944 (netdata) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 943 (DAEMON_SPAWN) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 946 (netdata) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1061 (DBENGINE) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1062 (UV_WORKER[2]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1063 (UV_WORKER[1]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1064 (UV_WORKER[16]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1065 (UV_WORKER[3]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1067 (UV_WORKER[5]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1068 (UV_WORKER[13]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1069 (UV_WORKER[7]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1070 (UV_WORKER[6]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1071 (UV_WORKER[8]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1072 (UV_WORKER[10]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1073 (UV_WORKER[14]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1074 (UV_WORKER[9]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1075 (UV_WORKER[12]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1076 (UV_WORKER[11]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1077 (UV_WORKER[15]) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1078 (METASYNC) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Killing process 1104 (DYNCFG) with signal SIGKILL.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Main process exited, code=killed, status=9/KILL
Aug 31 00:12:04 blue systemd[1]: netdata.service: Failed with result 'timeout'.
Aug 31 00:12:04 blue systemd[1]: Stopped Real time performance monitoring.
Aug 31 00:12:04 blue systemd[1]: netdata.service: Consumed 2h 11min 20.759s CPU time.
Aug 31 00:12:09 blue systemd[1]: Starting Real time performance monitoring...
Aug 31 00:12:09 blue systemd[1]: Started Real time performance monitoring.
Aug 31 00:12:10 blue [10208]: PROCFILE: Cannot open file '/opt/netdata/etc/netdata/apps_groups.conf'
Aug 31 00:12:10 blue [10208]: Cannot read process groups configuration file '/opt/netdata/etc/netdata/apps_groups.conf'. Will try '/op>
Aug 31 00:12:10 blue [10208]: Loaded config file '/opt/netdata/usr/lib/netdata/conf.d/apps_groups.conf'
Aug 31 00:12:10 blue [10208]: started on pid 10208
Aug 31 00:12:10 blue [10208]: set name of thread 10235 to APPS_READER
Aug 31 00:12:10 blue [10241]: no charts enabled - nothing to do.
Aug 31 00:12:10 blue [10257]: Does not have a configuration file inside `/opt/netdata/etc/netdata/ebpf.d.conf. It will try to load sto>
Aug 31 00:12:10 blue [10257]: Cannot read process groups configuration file '/opt/netdata/etc/netdata/apps_groups.conf'. Will try '/op>
Aug 31 00:12:10 blue [10257]: thread created with task id 10283
Aug 31 00:12:10 blue [10257]: set name of thread 10283 to EBPF OOMKILL
Aug 31 00:12:10 blue [10257]: thread created with task id 10284
The config is the default config.
/opt/netdata/var/log/netdata/debug.log is empty.
Is there any way we can figure out what happened?
