i see what you mean - i can see it on my prom charts like below:
link netdata.cloud/spaces/ml-demo-space/rooms/all-nodes/nodes/df9fbcba-2d32-4170-92ae-3dead1752313#6045dc92-0a0c-48d8-960c-d2e0f31aa95d-df9fbcba-2d32-4170-92ae-3dead1752313-chartName=menu_prometheus_node_exporter_demo_cpu_1s
@ben its the uuid for the room - so its sort of a constant that’s going to be the same for all charts in a room.
can i ask what the use case here is - so i can understand if is a feature request we should make here if this uuid part if a blocker of some functionality of more of an annoyance in terms of making the urls a bit harder to reason and work with.
Aha! Sorry for disturbing then. I could have checked msyelf that’s its same across nodes.
I have implementing “hacky” solution to send slack messages about each node. And In them I want link directly to the graph that raised “alarm”. Now it’s good. Let’s mark this as solved. Thank you for explaining.
cool, makes sense, i might make a feature request to clean up the urls like this on FE so its more intuitive for users wanting to use them for whatever reason as it is a little confusing with that room_id prefix and dont think it should be needed.
