I have deployed netdata via helm. All child nodes are successfully deployed but the parent pod has an error of
0/12 nodes are available: 12 node(s) didn't match PersistentVolume's node affinity. preemption: 0/12 nodes are available: 12 Preemption is not helpful for scheduling.
My storage class is like:
kind: StorageClass
metadata:
uid: 5982b3aa-7a9e-48d0-b53b-f80e6d738697
resourceVersion: '458821127'
creationTimestamp: '2023-03-25T22:36:54Z'
annotations:
kubectl.kubernetes.io/last-applied-configuration: >
{"apiVersion":"storage.k8s.io/v1","kind":"StorageClass","metadata":{"annotations":{"storageclass.kubernetes.io/is-default-class":"true"},"name":"resource-storage"},"parameters":{"fsType":"ext4","type":"gp2"},"provisioner":"kubernetes.io/aws-ebs"}
storageclass.kubernetes.io/is-default-class: 'true'
selfLink: /apis/storage.k8s.io/v1/storageclasses/resource-storage
spec: {}
provisioner: kubernetes.io/aws-ebs
parameters:
fsType: ext4
type: gp2
reclaimPolicy: Delete
allowVolumeExpansion: true
volumeBindingMode: Immediate
Used Helm Values:
replicaCount: 1
service:
type: ClusterIP
port: 19999
annotations: { }
ingress:
enabled: false
serviceAccount:
create: true
restarter:
enabled: true
schedule: "00 06 * * *"
image:
repository: bitnami/kubectl
tag: 1.25
pullPolicy: Always
restartPolicy: Never
resources: { }
concurrencyPolicy: Forbid
startingDeadlineSeconds: 60
successfulJobsHistoryLimit: 3
failedJobsHistoryLimit: 3
notifications:
slack:
webhook_url: ""
recipient: ""
parent:
hostname: "netdata-parent"
enabled: true
port: 19999
resources: { }
# limits:
# cpu: 4
# memory: 4096Mi
# requests:
# cpu: 4
# memory: 4096Mi
livenessProbe:
initialDelaySeconds: 0
failureThreshold: 3
periodSeconds: 30
successThreshold: 1
timeoutSeconds: 1
readinessProbe:
failureThreshold: 3
periodSeconds: 30
successThreshold: 1
timeoutSeconds: 1
securityContext:
runAsUser: 201
runAsGroup: 201
fsGroup: 201
terminationGracePeriodSeconds: 300
nodeSelector: { }
tolerations: [ ]
affinity: { }
priorityClassName: ""
env: { }
## To disable anonymous statistics:
# DO_NOT_TRACK: 1
envFrom: [ ]
## E.g. to read Netdata Cloud claim token from an existing secret "netdata" set this to:
# - secretRef:
# name: netdata
## And create it with: kubectl create secret generic netdata --from-literal="NETDATA_CLAIM_TOKEN=<token>"
## Also ensure that claim.token is empty
podLabels: { }
podAnnotations: { }
dnsPolicy: Default
database:
persistence: true
storageclass: "resource-storage"
volumesize: 50Gi
alarms:
persistence: true
volumesize: 5Gi
configs:
netdata:
enabled: true
path: /etc/netdata/netdata.conf
data: |
hostname = {{ .Values.parent.hostname }}
[db]
mode = dbengine
[plugins]
cgroups = no
tc = no
check for new plugins every = 72000
python.d = no
charts.d = no
go.d = no
node.d = no
apps = no
proc = no
idlejitter = no
diskspace = no
stream:
enabled: true
path: /etc/netdata/stream.conf
data: |
[11111111-2222-3333-4444-555555555555]
enabled = yes
history = 3600
allow from = *
health:
enabled: true
path: /etc/netdata/health_alarm_notify.conf
data: |
SEND_EMAIL="NO"
SEND_SLACK="YES"
SLACK_WEBHOOK_URL="{{ .Values.notifications.slack.webhook_url }}"
DEFAULT_RECIPIENT_SLACK="{{ .Values.notifications.slack.recipient }}"
exporting:
enabled: false
path: /etc/netdata/exporting.conf
data: ""
example:
enabled: false
path: /etc/netdata/health.d/example.conf
data: |
alarm: example_alarm1
on: example.random
every: 2s
warn: $random1 > (($status >= $WARNING) ? (70) : (80))
crit: $random1 > (($status == $CRITICAL) ? (80) : (90))
info: random
to: sysadmin
extraVolumeMounts: [ ]
extraVolumes: [ ]
extraInitContainers: [ ]
child:
enabled: true
port: "{{ .Values.parent.port }}"
updateStrategy: { }
resources: { }
livenessProbe:
failureThreshold: 3
periodSeconds: 30
successThreshold: 1
timeoutSeconds: 1
readinessProbe:
failureThreshold: 3
periodSeconds: 30
successThreshold: 1
timeoutSeconds: 1
nodeSelector: { }
tolerations:
- operator: Exists
effect: NoSchedule
affinity: { }
podLabels: { }
podAnnotationAppArmor:
enabled: true
podAnnotations: { }
hostNetwork: true
dnsPolicy: ClusterFirstWithHostNet
persistence:
enabled: true
hostPath: /var/lib/netdata-k8s-child
podsMetadata:
useKubelet: false
kubeletUrl: "https://localhost:10250"
configs:
netdata:
enabled: true
data: |
[db]
mode = ram
[web]
bind to = localhost:19999
[health]
enabled = no
[ml]
enabled = no
stream:
enabled: true
data: |
[stream]
enabled = {{ ternary "yes" "no" .Values.parent.enabled }}
destination = netdata:{{ .Values.service.port }}
api key = 11111111-2222-3333-4444-555555555555
timeout seconds = 60
buffer size bytes = 1048576
reconnect delay seconds = 5
exporting:
enabled: false
data: ""
go.d:
enabled: true
path: /etc/netdata/go.d.conf
data: |
modules:
pulsar: no
prometheus: yes
kubelet:
enabled: true
path: /etc/netdata/go.d/k8s_kubelet.conf
data: |
update_every: 1
autodetection_retry: 0
jobs:
- url: http://127.0.0.1:10255/metrics
- url: https://localhost:10250/metrics
tls_skip_verify: yes
kubeproxy:
enabled: true
path: /etc/netdata/go.d/k8s_kubeproxy.conf
data: |
update_every: 1
jobs:
- url: http://127.0.0.1:10249/metrics
env: { }
# DO_NOT_TRACK: 1
envFrom: [ ]
# - secretRef:
# name: netdata
claiming:
enabled: false
token: ""
rooms: ""
url: "https://api.netdata.cloud"
## Additional volume mounts for netdata child
## E.g to mount all disks under / to be monitored via the diskspace plugin
# - name: hostroot
# mountPath: /host/root
# readOnly: true
# mountPropagation: HostToContainer
extraVolumes: [ ]
## Additional volumes for netdata child
# - name: hostroot
# hostPath:
# path: /
k8sState:
hostname: "netdata-k8s-state"
enabled: true
resources: { }
# limits:
# cpu: 4
# memory: 4096Mi
# requests:
# cpu: 4
# memory: 4096Mi
livenessProbe:
failureThreshold: 3
periodSeconds: 30
successThreshold: 1
timeoutSeconds: 1
readinessProbe:
failureThreshold: 3
periodSeconds: 30
successThreshold: 1
timeoutSeconds: 1
nodeSelector: { }
tolerations: [ ]
affinity: { }
podLabels: { }
enabled: true
podAnnotations: { }
persistence:
enabled: true
volumesize: 5Gi
configs:
netdata:
enabled: true
data: |
hostname = {{ .Values.k8sState.hostname }}
[db]
mode = ram
[web]
[health]
enabled = no
[ml]
enabled = no
[plugins]
timex = no
checks = no
idlejitter = no
tc = no
diskspace = no
proc = no
cgroups = no
slabinfo = no
perf = no
go.d = yes
ioping = no
ebpf = no
charts.d = no
apps = no
python.d = no
fping = no
stream:
enabled: true
data: |
[stream]
exporting:
enabled: false
data: ""
go.d:
enabled: true
data: |
default_run: no
modules:
k8s_state: yes
go.d-k8s_state:
enabled: true
path: /etc/netdata/go.d/k8s_state.conf
data: |
jobs:
- name: k8s_state
update_every: 1
env: { }
# DO_NOT_TRACK: 1
envFrom: [ ]
# - secretRef:
# name: netdata
claiming:
enabled: false
token: ""
rooms: ""
extraVolumes: [ ]
Any suggesstions ?
- I tried with a default helm values. But that did not work aswell.
