I’ve jsut setup a new box to use Jitsi on it, but before that I’ve installed Netdata. Everything was working as expected.
During the installation of Jitsi, you will get asked to either provide a certificate or use a self signed one. I went with the selfsigned one but replaced it with one from Let’s Encrypt right after the base install of Jitsi by running the provided script:
/usr/share/jitsi-meet/scripts/install-letsencrypt-cert.sh
This went smooth too and Jitsi is working over SSL fine. However now when I try to access the web frontend of Netadata, I often get re-directed to the HTTPS site and get an error stating:
SSL_ERROR_RX_RECORD_TOO_LONG
Any idea how to fix that ?
Environment
Debian 10
